GBA Flash Card + Wisebox + Pegasos
    Posts: 34 from 2004/4/8
    Hello
    I buy a Wisebox GBA Flash copier, writer and a flash card. First i try use it under windows. Windows always have failures and blue deaths with the parallel driver of this hw. It is the windows we use in work, i dont have pcs at home. My question is: any pc emulator on pegasos (linux / MorphOS ) can handle the Pegasos II parallel port ? Or i can install the drivers under linux with Wine ? How fast the wine under linuxppc ? As i know there is no existing linux driver for the wisebox. Please help me
  • »26.10.04 - 10:54
    Posts: 979 from 2003/6/28
    You can ask to the UCON64 programmers*
    http://ucon64.sourceforge.net
  • »26.10.04 - 17:05
