Posts: 2732 from 2003/2/24
gazsp wrote:
Hi all, I'm looking into possibly buying a Pegasos II and i was wondering if the Peg has onboard USB and sound headers.
Yes it has!
It has the following headers on the motherboard (in addition to the connectors on the rear panel):
1 Firewere (standard motherboard connector)
1 USB (on the "geeky" header-row)
1 IR (on the same row)
1 I2C bus (on the same row)
*AFAIK* 1 Second Gigabit Ethernet (needs a not yet available tool/PCB "connector" that connects to the small slot just above the CPU card (where the PSU connector was on the Peg1))
1 Audio In (CD In)
1 Audio In (Video In)
1 Audio In (AUX In)
1 Headphones
1 Microphone
+ the regulars, such as various LED's, internal speaker, etc.
[ Edited by takemehomegrandma on 2004/8/31 20:30 ]
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
