It's possible use the I2C bus of Pegasos II?
    Posts: 979 from 2003/6/28
    It's possible use the I2P bus of Pegasos in MorphOS and linux? Anyone use it for something? I'm interested on i2p and if Pegasos II has one inside,, could be nice can use it...
  • »05.09.04 - 16:43
    Posts: 408 from 2004/7/15
    I think it should have it, but:
    1. It seems to be unused.
    2. It has no external connectors and soldering at the board is not good IMO.
    3. I have DS1621 thermometer which worked with my Amiga (i connected it to joystick port and wrote a program which displayed temperature), unfortunately the program was not finished so it was never released. I'd like to bring this thing to Pegasos. Let's cooperate? I suggest to use paraller port for it. Probably there are some PCI cards which implement external I2C bus - i don't know. Anyway it's very easy to implement I2C in software
    4. There are i2c.library on Aminet. This can be considered as standard. Of course that implementation works with old Amiga hardware and uses very strange connection schematics, but we can write new library with the same API (in fact the system is designed like for example XPR subsystem where we have different libraries with the same API so we can just choose appropriate library for our system).
    iPod, iBook, iMac,... iRobot?
  • »06.09.04 - 11:32
    Could be nice an OpenPCI driver for some really good I2C PCI card. I want use I2C in electronic...
    I'm not a programmer (I'm still starting to learn C) but I can help in testing purposes...
  • »06.09.04 - 22:07
