Best sound card for MorphOS?
    Posts: 979 from 2003/6/28
    Which is the best sound card for MorphOS in terms of sound quality and compatibility?
  • »14.08.04 - 09:25
    Posts: 1932 from 2003/10/19
    You will have to see what drivers are avail for others through it, but i use a SB Live card. The driver comes in the newer AHI packages. I like the sound much better over the onboard sound.
  • »14.08.04 - 09:50
    What about Audigy? And Audigy 2? And Terratech?
  • »14.08.04 - 15:48
    I dont think any of them are supported on the Pegasos or AHI are they becides the Terratech one?
  • »14.08.04 - 17:22
    Any can explain about this, please? The AHI developer, for example?
    AHI supports Audigy 2?
    What about this?
    http://opensource.creative.com
  • »15.08.04 - 16:37
    Posts: 236 from 2003/7/28
    I used to use a SoundBlaster Live! in my Peg-1, and then I switched to on-boards sound. I really didn't see any difference in CPU usage or quality when playing back MP3's on normal desktop stereo speakers.
    Perhaps if you had really high-quality speakers and were playing back clean CD audio you might see a difference. But for general desktop usage you won't see a difference between a Soundblaster live! and on-board peg-1 or peg-2 audio.
  • »15.08.04 - 16:38
    @Robin
    Creative Audigy is supported and not showed on that webpage, so I assume that maybne there are other sound cards supported and not listed...
  • »15.08.04 - 17:39
    serge
    Posts: 725 from 2003/2/20
    where can I found the SoundBlaster driver for AHI ?
  • »15.08.04 - 17:41
    http://www.lysator.liu.se/~lcs/files/ahi/beta/ I think...
  • »15.08.04 - 17:44
    Robin
    Posts: 741 from 2003/2/24
    From the Changelog:
    * emu10kx.audio: Replaced the EMU10k1 routing completely. Disabled
    most of the patch manager. Somebody needs to fix it for Audigy
    cards.
  • »15.08.04 - 17:56
    poundsmack
    Posts: 1346 from 2003/6/7
    isnt the onboard sound pretty darn good in the peg? why even bother with another card?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »16.08.04 - 02:02
    @Poundsmack
    the sound you heard at Amiwest was from my Soundblaster Live card. With my speakeers you can hear a real diffrence between the two. Also at times the onboard sound would skip if I was doing a lot of things at once, with the live card I never have that problem.
  • »16.08.04 - 15:08
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    I agree with Acill here, his soundblaster live sounded 'punchier' if that's the right word for it. I have incredibly cheap altec lansing sub/satellite speakers on my system so it doesn't matter a great deal to me. Acill's sounds could have been better purely because of speaker quality :-)
    Re: sound skipping. You have to really bog the system down to make the sound skip...of course one surefire way of doing it is to run stuff that disable multi-tasking like, for example when you have a few screens open and CGX runs out of VRAM and has to do a buffer swap to main memory. That example is the only time I get a sound stutter/skip under regular use. (well, since I installed RexxMast to fix the Voyager bug ;-) )
    Cheers,
    Steve
  • »16.08.04 - 15:33
    pegasosuser
    Posts: 138 from 2004/4/9
    I have build a Soundblaster Live! soundcard and this working verry
    good!
    this better then the sound AC97 onboard!
    Greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »23.08.04 - 19:43
    good!
    I am glad you were able to get it working for you! I also agree the sound is much cleaner then the onboard AC97 chip produces. Even more so if you have a good audio system.
  • »23.08.04 - 22:06
    Define good audio system.
    I don't know about that. What doi you have? What are the good options?
    Do you use 5.1? 7.1?
  • »23.08.04 - 22:50
    Chain-Q
    Posts: 350 from 2003/10/12
    good!
    What kind of mixer are you using for SB Live!, to set the volume levels of output(s)/input(s)?
    [.Hosting AmigaSpirit.hu.]
  • »24.08.04 - 05:26
    Currently no mixer is avail, but the levels that its at are just fine without one. I hear a live mixer is in the works though.
  • »24.08.04 - 08:26
    pegasosuser
    Now there is a mixer aviable! for the Soundblaster Live! and this
    working verry good!
    greetings Cor van Londen.
  • »05.09.04 - 17:34
