Null Modem/Serial Debug on Peg2 Questions
    magnetic
    Posts: 2129 from 2003/3/1
    Hi all
    My peg2 g4 is down... :-(
    It goes to the OF screen and tries to launch MOS but it never gets past the OF. Seems like there is some sort of problem. I tried alot of hardware stuff - changing cards and ram and such I think I need to see the debug log.
    I have an A4000T here as well and 2 ibooks. I'd like to hook up the peg2 to my Amiga with a null modem cable and see the debug output. How do I do this? What freely available software for Amiga can I use? Also, what special setup do I need? Any and all help is appreciated.
    magnetic
  • »31.08.04 - 08:15
    Posts: 2077 from 2003/6/4
    It is very easy to obtain the serial debug.
    Just connect the serial port of your Peg with that one of your Amiga (the slow Amiga serial port is fast enough) by using a null modem cable and boot with the according boot parameter (have to check the command for verbose debug output when I am at home). (Edit: of course the boot options are not of interest in your case, the first init puts always a serial debug)
    On the Amiga just use some terminal software (I guess I use term, dunno for sure, Aminet has several terminal programms).
    Configuration of the terminal is easy, just fetch all from the serial port (use a big buffer) and write it into a file.
    I don't know the details from just remebering (not at home now) but it was *really* easy. if questions are still present I can check the details when at home.
    [ Edited by Zylesea on 2004/8/31 13:55 ]
  • »31.08.04 - 09:50
    ChatDEau
    Posts: 248 from 2003/4/4
    @magnetic
    Do you see the "Quark/Firmware"-something line?
    If yes, try booting with the MOS original CD. If it boots, it's only your actual MOS installation that has a problem, or the HD its installed on.
    Hope it helps
    Fred
  • »31.08.04 - 10:06
    Posts: 979 from 2003/6/28
    @magnetic
    I'm still waiting about your response of symbios 895. I was sended the money to your paypal account, I don't like to use a public forum for this, but you not reply me and post on MZ forum, so it seems that you simply ignore me.
  • »31.08.04 - 12:44
    BUMP
    Magnetic, I'm still waiting your reply...
  • »01.09.04 - 07:42
    magnetic
    Timo
    Please keep biz comms private. That is silly. We received your payment and will ship shortly. Thank you much. I have been very busy.
    (The only reason I respond in these threads to you is to stop the OT nature of it :-( )
    @ the others in thread
    Thanks for your help and can you please offer some more specific settings/advice?
    TIA
    magnetic
  • »01.09.04 - 15:21
    ultraspec
    Posts: 94 from 2004/1/29
    Hi magnetic. I use a serial cable and a null modem adapter to do this. Plug end with the null modem adapter into your Amiga.
    You can use any terminal program. Set the comm paramaters to 115200 8N1 no flow control.
    I always use minicom in Linux.
    Then I unplug the keyboard from the pegasos and reboot it, and read the output on the terminal's screen.
  • »01.09.04 - 15:26
    Neko
    Posts: 301 from 2003/2/24
    You can't go far wrong with Olaf Barthel's Term app for Amiga. It's on Aminet, comm/term directory (searching for it is a nightmare, but it is there :)
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »01.09.04 - 17:11
