1024Mb DDRam
    pegasosuser
    Posts: 138 from 2004/4/9
    not all problems it's working better but after twenty minuts slowdown
    and hanging with 1024DDRam
    not with a single 512DDRam!
    Greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »22.08.04 - 23:37
    Posts: 979 from 2003/6/28
    I have same problems and I'm using one 512MB DDRam, I was tried with
    the MorphOS 1.4.2 CD, still crashes copying/deleting a large amount
    offiles/one file or executing some apps...
    This is a hardware problem then, Pegasos II or memory? Debuggin' can
    say it...
    Memory here...
    memory chips:
    ACE
    EC064088JD
    M73408
    crap drawed...
    The stick
    512MB DDR 400MHz
    64Mx64 PC3200
    [ Edited by timofonic on 2004/8/23 6:44 ]
  • »23.08.04 - 01:04
    Here is the log: http://www.iespana.es/damospena/morphos.log
    What occour on MZ? I can't upload files...
  • »23.08.04 - 18:53
    pegasosuser
    I think this a software problem
    it could better with MorphOS1.5 and bios update
    this not the PEGASOS!
    this come good!
    We are waiting for MorphOS1.5!
    coming soon!
  • »23.08.04 - 21:36
    @pegasosuser
    WTF is Cor Van Londen?
    Why isn't hardware problem? It has problems with MorphOS 1.4.2 CD, and
    before this was runned correctly, crap DDRam and is fucked due to be
    bad maked? We need an A LOT improved OF, solving memory issues and a
    lot of others, and why not a nodebug option?
    EDIT: The debuglog is from booting MorphOS 1.4.2 CD and using
    ramdebug...
    [ Edited by timofonic on 2004/8/23 23:34 ]
  • »23.08.04 - 22:32
    Changed th DDRam to a Kingston ValueRAM 512MB PC3200 400mhz model
    KVR400X64C3A/512 and same problems, so this memory has problems too
    (seems improbably) or is another hardware problem...
    Any opinions, please?
  • »24.08.04 - 22:14
    Another problem verified:
    Sometimes the network not runs after booting/stops running after some
    use, and Voyager is SLOW loading pages.
    All these problems and as It happened of the explained problems, seems
    a progressive deterioration (at start hasn't problems, but sonme time
    more the problems appeared) due to a failure in the manufacture of
    the Pegasos II, something that has caused that has has problems after
    some time instead of being it from the beginning. I'm not an expert,
    only a simple user that suspects something, I know that there are
    manufacturer failures on all companies, some product can has a failure
    due to various aspects...
    Please, do It can any help me? I'm waiting the registration of the
    Beta2 mailing list...
  • »25.08.04 - 00:18
