It's good this (incredibly small) power supply for an Pegaso
    Posts: 979 from 2003/6/28
    http://store.mini-box.com/ituner/pw1220atxmip1.html
    It's ####### small!
    What about this? It can gives some problems? It can power a Pegasos II G3/G4 +256/512/1024 MB DDR + 2 WD IDE 160GB disks + CDRW + SCSI controller + voodoo3000/voodoo4500/radeon7000 AGP? 205Watt all this? I dont know the power of all those devices, if one know, please calculate it...
    NOTE: This isn't exactly a PSU, It needs a 12v imput, but it's very good because not gives heat inside the computer (remember:pegasos is cool computing!!!), like A500/A1200 and a lot of videogame systems! ;-)
    [ Edited by timofonic on 2004/8/20 22:55 ]
    [ Edited by Targhan on 2004/8/20 17:32 ]
  • »20.08.04 - 18:54
    Posts: 1932 from 2003/10/19
    Wow that is cool! i think it would work just fine for a Pegasos II as long as you had a good AC to DC converter to use your wall outlets. If you have a DC power supply its perfect. I could use that to make one hell of a nice compact system.
    Check out this site: http://www.mini-itx.com/store/default.asp?c=10
    [ Edited by Acill on 2004/8/20 18:23 ]
  • »20.08.04 - 20:30
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    That looks COOL timofonic, good find!
  • »21.08.04 - 00:29
    ironfist
    Posts: 254 from 2004/4/22
    It will only fit as long as you use an extender cable
    between the PSU and motherboard. But I suppose
    you have already figured that out.
    There are loads of fanless PSU for the Mini-ITX market.
    Here is the same PSU but only rated at 100W.
    100W is perfect for a normal Pegasos workstation
    with 1 5.25" Unit, 1 HDD and a gfx card.
    [ Edited by ironfist on 2004/8/21 7:56 ]
  • »21.08.04 - 03:53
    If you take a look at the link I sent in my last post, several more types are out that will work. I did look at the one mentioned at the start of this thread. It will not work because it hangs over the CPU card. An extender will work well with it though if you dont mond locating it in another area of the case you select.
  • »21.08.04 - 11:35
