PCI Cards.
    pegasosuser
    Posts: 138 from 2004/4/9
    I would build a PCI card Ultra ATA 133 for intern devices
    and a sound card bv Soundblaster Live! of other
    wich cards are good and working on PEGASOSII and MorphOS1.4.2
    TNX!
    greetings from: Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »20.08.04 - 16:50
    Posts: 1931 from 2003/10/19
    I dont know about PCI ATA 133 cards, but I have used a Soundblaster 128, Soundblaster Live!, and a FM801 card. The Live card is very good and I am still using it with the latest version of AHI.
  • »20.08.04 - 16:53
    pegasosuser
    TNX Acill!
    I looking for that card (Soundblaster Live!)
    and You hearing from My of that Card.
    greetings from Cor van Londen a PEGASOSII user!
  • »20.08.04 - 17:30
    Posts: 979 from 2003/6/28
    And what about Audigy?
  • »20.08.04 - 18:06
    pegasosuser
    would the Audigy 2 working? that's 24Bit soundcard and the
    Soundblaster Live! 16bit.
  • »20.08.04 - 19:25
    Yes I have heard the EMU10K driver supports it, though I havent tried. You may need to take a look at the doc file in the latest release of AHI to make sure.
  • »21.08.04 - 00:40
    pegasosuser
    where can I find the EMU10k driver?
    TNX!
    Cor van Londen.
  • »21.08.04 - 09:16
    pegasosuser
    TNX!
    I have found de device driver emu10k and works fine! clean sound
    better than sound onboard!
  • »21.08.04 - 11:35
    @pegasosuser
    Audigy2 working on MorphOS?
  • »21.08.04 - 12:09
    docgeddy
    Posts: 37 from 2003/7/31
    would be nice to see a mixer for the SB Live cards. :)
    DocGeddy
    Member of Butterfly Army
  • »21.08.04 - 12:17
    Someone was working on one I heard, but then nothing said of it. anyone hear anything of it?
  • »21.08.04 - 14:23
