Palm support.
    matt3
    Posts: 782 from 2004/2/10
    Is there any support for Palm Pilots and MorphOS?
    If yes what palm with what software and scheduler?
    Thanks,
    Matt
  • »11.06.04 - 12:44
    GK_LKA
    Posts: 481 from 2004/3/28
    AFAIK there is no support for Palms at the moment. :(( I've read a lot in this topic, and the result was the following: SpitFire does not support pegasos' serial.device even in low speeds (donnowhy) but there is a device called usbraw.device for this things, but SF does not support it either (donnowhy).
    If you want to use your Palm with your Pegasos, the only way is to use linux. Maybe sometime somebody ports these programs to MorphOS...
    [ GK / LKA Team ]
  • »11.06.04 - 13:14
    warface
    Posts: 653 from 2003/2/24
    A PalmDesktop clone would be an ideal subject of the upcoming MorphOS Bounty program.
  • »11.06.04 - 16:30
    Posts: 126 from 2003/2/17
    aminet: spitfire2 software
    but doesn't support latest palm models... would need update
    works fine here with palm m105 and serial dock
  • »11.06.04 - 18:23
    Posts: 979 from 2003/6/28
    http://www.pilot-link.org
  • »11.06.04 - 18:41
    Posts: 81 from 2004/3/20
    KDE on the Debian side has KPilot which supports installing, and some Palm OS synchs and conduits.
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »12.06.04 - 12:52
    @HarryO43
    Sorry but we want use it with OUR main OS, not linux... And using the native, homogenous and extremely fast native MUI ;-)
    With pilot-link, that supports a lot of Palm devices, we will have the main and dificult task finished, and its possible make the things by console... Make a MUI gui will be easier...
    Problems? MorphOS dont support bluetooth, so bluetooth support will cant be activated until a bluetooth stack (and drivers for controllers, better if usb bt adapters) is available for MorphOS. Another thing is that will need to be adapted for use poseidon USB stack...
  • »13.06.04 - 06:37
    Jupp3
    Posts: 1193 from 2003/2/24
    Yep, but it could also be ported to MorphOS :-)
  • »13.06.04 - 07:24
    GK_LKA
    I'd be happy if I only a console-based stuff have for syncronizing my Palm (e.g. pilot-link).
    Does anybody know, how hard is to port this stuff? I think, the only difference is in USB-handling.
    [ GK / LKA Team ]
  • »13.06.04 - 17:13
    Looked into my linux logs today to figure out what device the palm is using after a synch. The information from the palm is in both the messages and system log, but no device is specified where it's getting the strings from. I've been trying to set up kpilot to at least use SOME of the features of the palm I have with the Peg II.
    Harry
  • »13.06.04 - 23:42
    matt3
    Looks like I have to wait until it's ported.
    Thanks guys for the great feed back.
    Matt
  • »14.06.04 - 00:33
    Lets see who port it! ;-)
  • »14.06.04 - 07:24
    Posts: 1932 from 2003/10/19
    The bluetooth stack should be easy to get some ideas on or even take one of the open source bluetooth stacks out and port. Here is a good search that has lots of them listed: http://www.google.com/search?q=open+source+bluetooth&sourceid=mozilla-search&start=0&start=0&ie=utf-8&oe=utf-8
    I hope we can get some Palm software working too. that would be great!
  • »14.06.04 - 10:08
    GK_LKA
    @HarryO43:
    It uses /dev/ttyUSB/ttyUSB1. I think this is a kind of serial over USB emulation.
    [ GK / LKA Team ]
  • »14.06.04 - 16:18
  • Ex-Member
    Posts: 74 from 2004/6/15
    Bye...
    Chris Hodges
  • »15.06.04 - 07:01
    GK_LKA
    Music for my ears :)
    I hope it will fully work in the near future. (PS: Could you send me these files?)
    [ GK / LKA Team ]
  • »15.06.04 - 08:19
  • Ex-Member
    File upload works, Spitfire works (a bit flakey though, but I'd rather blame this on Spitfire).
    I can't send you the files for several reasons.
    a) it is beta and not for the public.
    b) I haven't compiled PPC binaries yet.
    c) you cannot exchange the poseidon library in the MOS-Bootimg.
    d) Some internal reasons ;)
    Bye...
    Chris Hodges
  • »15.06.04 - 09:25
  • Targhan
    Posts: 2833 from 2003/2/7
    Welcome platon42. Glad to see some kind of palm support. I don't know how helpful this is, but Vapor had some kind of palm interface software that would be interesting to see what could happen with...
    Everyone will come after me with guns if it ends up being a Vapor/Shareware upgrade rather than an internal one :-P
    :idea:Targhan
  • »15.06.04 - 14:18
  • Ex-Member
    Hi Targhan!
    I was pretty surprised, but looking at www.vapor.com about AmigaNCP, it is /not/ software for Palms, but for Psion PDAs. This is something different indeed ;)
    Bye...
    Chris Hodges
  • »16.06.04 - 06:52
    Haven't had much of a chance to fiddle with it in the past week or so, but will give it a shot! Thanks GK_LKA!
    Regards,
    Harry
  • »26.06.04 - 10:18
