Which DVD-RW works on Peg/Mos1.4?
  • Lee
    Lee
    Posts: 70 from 2003/4/9
    yesterday i bought me the Sony DWU-18 A10 (only 77Eu) but it doesnt work here on my PegI. :-(
    Please tell me what DVD-RW work on Peg, we can do it into a list...
    thanks
  • »16.05.04 - 09:43
  • Ray
    Ray
    Posts: 21 from 2003/2/24
    Pioneer DVR-106D works here.
  • »16.05.04 - 16:56
    magnetic
    Posts: 2129 from 2003/3/1
    What do you guys mean by "Works" please describe. Does the Pioneer work with Mplayer and DVD?
    magnetic
  • »17.05.04 - 01:47
  • Targhan
    Posts: 2833 from 2003/2/7
    I propose we create a list with the appropriate software vendors... Something like the following:
    Drive List:
    Manufacturer, Model, CD Read, DVD Read
    On that page, we should either duplicate or link to the software vendors for CD/DVD writers. Also, it should include a list of DVD drives supported by MPlayer and FroggerNG.
    :idea:Targhan
  • »17.05.04 - 03:27
    Jupp3
    Posts: 1193 from 2003/2/24
    And not forgetting the most important:
    Works with dvdrtools: yes/no
  • »17.05.04 - 05:43
  • Lee
    Lee
    Well, i try out a new one.
    And this are also not work!
    The LDR8844 8-in-1 from Speer Computers does not work.
    Now i will try a NEC... :-)
  • »17.05.04 - 10:59
  • Lee
    Lee
    Jabadu! :-)
    Here is a working DVD-RW Drive.
    NEC ND-2500A 8xDVDR+/- means DVD and CD read okay.
    Burn function will prove if burnit relased.
  • »28.05.04 - 05:00
    Jupp3
    Meanwhile, why don't you try it with dvdrtools?
  • »28.05.04 - 05:20
    Posts: 1932 from 2003/10/19
    I remember that dvdr tools. Does it have a GUI or are they all command line? I want to get another DVD-R drive for my Pegasos.
  • »28.05.04 - 15:33
    magnetic
    Oh boy -
    it "works" wtf does that mean? ;-)
    can you be more specific please? We need this test data.
    Does it play DVD with MOS and Mplayer?
    .... in Linux?
    Can you burn DVD with K3b in linux?
    "......." with dvdrtools?
    Did you try Frying Pan?
    Thanks for your help please all lets test some drives...
    magnetic
  • »28.05.04 - 16:41
    Posts: 62 from 2003/7/30
    A NEC1300 works here to !!!!
    :-D
    it is a DVD-RW writes + and - dvd's
    also cd etc....
    only i am waiting for burnit to do much more better than copycd.
    copycd works here also but i hate the userinterface :-x
  • »28.05.04 - 16:44
    Hawk
    Posts: 204 from 2003/12/29
    from dvdrtools home page:
    "Thanks to the old dos.library AmigaOS is limitated to a maximum file size of 2 GB. This means that you can use readcd only for reading DVD`s with a maximum capacity of a bit less than 2 GB"
    Does this apply to Morphos? I guess we don't have any "old library" ...
    BTW, is there any PPC port of the code?
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »29.05.04 - 00:59
    Hawk
    I tried to burn a CD with dvdrtools, and after writing the track it says "writing" some negative number of *something* "data". I coudn't copy-paste the message because it just froze! The system hung up.... :-(
    Is gonna happen the same when recording DVDs? Anyone has any idea of what kind of problem is that?
    Thanks!
    EFIKA
  • »31.05.04 - 13:36
    Schlonz
    Posts: 131 from 2004/4/16
    AFAIK the old dos.library has been reimplemented in MorphOS - I think because of compatibility reasons.
    Even if I am not right with my guesses I mentioned above, this sucking 2 GB limit is in MorphOS, too.
  • »31.05.04 - 20:09
    Schlonz
    >I tried to burn a CD with dvdrtools, and after >writing the track it says "writing" some >negative number of *something* "data". I coudn't >copy-paste the message because it just froze! >The system hung up....
    >Is gonna happen the same when recording DVDs? >Anyone has any idea of what kind of problem is >that?
    When using dvdrecord from shell, did you set the stack high enough?
    When setting the stack to 500.000 or above all the dvdrtools proggies work fine here on my Peg1 G3/600 with MOS 1.4.2
    BTW: AFAIK there is currently no PPC version of the dvdrtools. I did not install the MOS version of gcc yet, but maybe I will do that in the near future and recompile dvdrtools for MOS. I do not think that a PPC version of dvdrtools is really necessary because the 68k version is quite fast on MOS.
  • »31.05.04 - 20:16
    Hawk
    mmm I set the stack to 500.000 as I read in dvdrtools page.... Maybe I should try upgrading Morphos to 1.4.2. I stucked with 1.4.1 + poseidon update, since I couldn't find where I put my access information to the download area in pegasos. Is it in the developer's area?
    EFIKA
  • »01.06.04 - 00:06
