G4 CPU Fan
    Aaron
    Posts: 127 from 2003/6/14
    My computer woke me up this morning with a thermal warning. After a
    few seconds of investigation I discovered that the CPU fan stopped
    spinning. I immediately shut the computer off.
    After work, I took the fan off of the heat sink and dropped some oil
    into it and even took the TT sticker off of the back and put a drop of
    oil onto the end of the shaft.
    The fan is working again and spinning strongly. The CPU is running
    cool once again. I wanted to put this out there to alert other G4
    owners.
    --Aaron
    --Aaron Diezman
  • »31.05.04 - 08:08
    bbrv
    Posts: 750 from 2003/2/14
    Thanks Aaron.
    You sure it was not sand from the bench? :-P
    What is the temperature and humidity like there?
    R&B
  • »31.05.04 - 12:01
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    Where can you see a thermal warning on a Pegasos II?
    I think my G3 freezed once because of temperature while using Linux, but since then no more problems.
    /proc/cpuinfo showed >35C, normally its around 25-30C (uncalibrated)...
  • »31.05.04 - 13:07
    Posts: 1926 from 2003/10/19
    Hmm good advice! I will take a look at mine to make sure all is well.
  • »31.05.04 - 13:19
    Neko
    Posts: 301 from 2003/2/24
    Are you a smoker, by chance?
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »31.05.04 - 15:55
    Hawk
    Posts: 204 from 2003/12/29
    I have a G3 without fan. cat /proc/cpuinfo tells me:
    processor : 0
    cpu : 745/755
    temperature : 32 C (uncalibrated)
    clock : 599MHz
    revision : 51.17 (pvr 0008 3311)
    bogomips : 1199.30
    machine : CHRP Pegasos2
    But I installed a thermal monitor, and the display shows now 59 degree! Of course, the sensor is over the heat sink. Doing more CPU intensive work it may get up to 66 degree. Still, it never hang up...
    By the way, I also took out the fan of my ATI Radeon 7500 and installed a bigger heat sink. It gets around 50 degree. I guess it should be ok ^^; With the fan was about 35 degree.
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »31.05.04 - 16:07
    hiTCH-HiKER
    I think mine is >60 degree, too... because when you touch it, it really is very hot... but I suppose it's designed to work at 60 degrees... I have absolutely no fans in my tower case, so it may be critical when performing cpu intensive stuff during a hot summer days... I have a passive cooled 7500 with 32MB SDRAM , which stays cool in 2D mode...
  • »31.05.04 - 17:57
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    I had *exactly* the same problem yesterday. Luckily I had installed thermal monitoring - I have probes on the NB and the G4 CPU heatsink. My thermal alarms are set to 55'C/50'C. I heared the alarm go...lo and behold the CPU fan was barely turning.
    Luckily I caught it before it got much warmer, as I run dnetc 24/7 it would surely have been toast without those external alarms.
    In two minds whether to return module to Genesi or just upgrade the CPU heatsink/fan myself.
    Steve
  • »31.05.04 - 19:30
    minator
    Posts: 370 from 2003/3/28
    IIRC if the CPU has no heatsink and it's 60 degrees the chip itself will be 70. Most seem to have a limit at something around 90 degrees.
    Best bet is to get a huge aluminium heat sink if you want to run it fanless but make sure it's attached properly and not touching anything apart from the CPU - you'll need to read around about how to do this properly.
    Thankfully you wont need this sort of cooling:
    http://www.theinquirer.net/?article=16247
  • »31.05.04 - 19:38
    Aaron
    @BBRV,
    Nope, no sand. :)
    The high temperature here is always 86-88 and the low is always 77-80.
    It's a very temperate climate here. The humidity is pretty high.
    It's anywhere between 85% and 100%.
    I live in an air conditioned building.
    --Aaron
    --Aaron Diezman
  • »31.05.04 - 21:40
    Aaron
    @hitch-hiker,
    My Peg is in a Thermaltake Xaser III tower and it has a temperature
    probe and it displays the temperature on the fan control unit.
    @Neko,
    I'm not a smoker and I live in a smoke-free building.
    --Aaron
    --Aaron Diezman
  • »31.05.04 - 21:46
