Posts: 459 from 2003/8/30
i'm not an expert, but for a job (which never happened
) i researched this. the cheapest solution is to get a thing (screen) that fits over the monitor. you need a driver for it.
after that you just make a simple html page. the links will work the same as using a mouse.
so, the trick is to get/make this driver. time to check what linux has.
