Poseidon, scanner, usb device
  • buh
    buh
    Posts: 68 from 2004/2/2
    I try to install an epson perfection 1650 (scanner) on peggy.
    Poseidon recognize it without problem and create a device in the trident's panel. It does not associate any class, but I, manullay, link the rawrap.class.
    All is done, but what's happened? Nothing.
    FxScan ask me a file for Epson (it is in a subdirectory with fxscan) and a device. But, what device? I have no device!
    Should Poseidon create a device in mossys:devs/USBHardware?
    I try with Poseidon included in Morphos disk installation and with Poseidon 2.2, but nothing.
    I have no device.
    Is there anybody which can suggest me anything?
  • »15.03.04 - 09:41
    Jupp3
    Posts: 1193 from 2003/2/24
    FxScan can use Betascan drivers, there are lots of those available at aminet...
  • »15.03.04 - 09:42
  • buh
    buh
    The epson perfection 1650 is an usb scanner.
    I think betascan does not support usb scanner but only scsi.
    But my usb scanner is supported by fxscan. I don't know which type of device I have to associate with fxscan.
    And I don't understand if Poseidon create some device when you plug in your new usb hardware.
  • »15.03.04 - 09:57
    amigafil
    Posts: 23 from 2003/9/6
    Do you read the Home/Product/Fxscan/support/iousb on iospirit web ?
    I think you find that you need. :-)
    Also it mistake a file that you find on superbundle...
    Powerbook and Pegasos II G4 MOS 3.7 :-)
  • »15.03.04 - 11:54
  • buh
    buh
    I read it but I don't understand where can I get the usbraw.device.
    I have no file in mossys: or ram:.
    Poseidon program does not create any type of file in mossys:devs. I have no directory in this place called USBHardware.
    If I install the new release (2.2) (may I install?) I find the directory USBHardware but only one device >> uhciusb.device.
    Shall poseidon create in this directory in runtime a new device when the new hardware plug into the system?
    Many thanks for the patience.
  • »15.03.04 - 12:46
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    You don't need any usbraw.device, just enter that device name in the device field of FXScan, choose device 0 and save, then it works!
    Before that you must ofcourse bind the rawrap.class to your scanner, like described on the IOSpirit page.
    If you still experience problems, just ask :)
  • »16.05.04 - 01:50
