EVX a écrit :
Hey all,
I grabbed a (USB) DeskJet 950C and it showed up in good shape. The printer checks out good and printed a test page just fine. I see the device is quite alive when I run "usbdevlister". I have followed the guides on getting the printer configured. I do see a warning when I add the PPD file:
This printer description requires CUPS filter: hpcups.
Are you sure you have installed it?
I picked "No, Let's try without CUPS filter".
(I extracted this 950C.PPD from a HPLIP.tar.gz for Ubuntu.)
I have the USBPAR: set as the output path, printer set to default, and I also mounted USBPAR: in the user-startup. USBPAR is in the DosDrivers Drawer.
After a reboot, does any one have any tips on why MultiView "Could not find printer" ?
Thanks much in advance,
-E
Good luck, there's no viable printing option.
Unless you can find a printer from the 2000s. That's unfortunate for a 25-year-old operating system.
