Posts: 2572 from 2003/4/10
Thanks for the recommended steps
With a JSAUX cable and the recommended steps the LED is ON now but impossible to force device binding to xbox360 class after many try, even a restart of the USB stack.
[EDIT] A strange thing, after a reset of the USB stack , i must always do SHARE + m to have the LED ON.
[EDIT2] "Same problem with another joystick normally compatible..."
Now the other gamecontroller has xbox360 class and work fine... bizarre
