Moderator
Posts: 2578 from 2003/2/24
DVI to VGA means you are using an analog signal which is AFAIK not supported for DualHead (outside the iMac where it is the only option).
"Old trusted Iiyama screen" sounds early LCD or even CRT which may not support DDC (mode recognition), better try with 2 proper digital screens.
And by "proper" I mean proper as I have a ca 2002 18" Phillips that has a DVI input only accepting VGA signals...
