Posts: 1385 from 2010/1/6
MorphOS handles fans well - i've 4 PMG5 (1,8-2,3GHz) all running very silent. (CPU ~ 55-65°C).
Only one G5/2GHz sometimes backsideblower (cooles Nrthbridge) becomes loud, but not often.
This seems to be a problem of your PM. If nothing changes by setting different CPU-temps (PowerMac7FanControl), then there is something wrong with fan control on your board (or fans). Every PM I've seen, reacts to different temp-settings (incuding 2.7GHz-watercooled G5)
Are you sure, the loud noise is'nt comeing from backsideblower?
