Jit thingie
    klapdeur
    Posts: 132 from 2003/6/28
    guys maybe stupid guestion but how do i enable disable JIT or how do
    ya call it
  • »18.04.04 - 18:23
    marcik
    Posts: 268 from 2003/4/12
    To disable:
    setenv SAVE NOTRANCE 1
    And after reset you'll have no trance active
    To enable:
    Delete ENVARC:NOTRANCE
    And after reset you'll trance back.
  • »18.04.04 - 18:28
  • Leo
    Leo
    Posts: 426 from 2003/8/18
    marcik wrote:
    To disable:
    To enable:
    Or more simple: (No need to reboot)
    .To disable JIT you bring up the taskmanager and send a ctrl+c to the "trance" task
    .To enable it again, just run Trance again
    .To disable it permanently, remove the entry from mossys:s/startup-sequence
    Leo.
  • »18.04.04 - 19:25
