Posts: 1385 from 2010/1/6
Limited it to 65° on 2.3 GHz. Fans are'nt noisy.
Think a 2.7GHz will go much more hot against a 2.3 GHz. So your 77° seems to be OK. But you should not allow more then 80°.
If you changed CPUs (between slots, or new CPUs) you MUST calibrate.
