External Audio Devices on MorphOS
    Zergei72
    Posts: 6 from 2012/11/17
    Hi ...
    Is it in any way possible to get any of the following hardware working on MorphOS ;
    Digidesign DIGI001 (PCI - based) / Rack 002 (Firewire - based)
    or
    Presonus FirePOD (Firewire - based)
    I would like to turn my PPC G4 QuickSilver 733MHz to a full featured DAW ...
    And I've found out, that there's some awesome soft for MorphOS (Audio Evolution), that's free .
    - Z -
  • »15.09.22 - 06:35
    cip060
    Posts: 151 from 2010/7/30
    The usb firewire peripherals are worth trying
    example my razor wifi headphones work fine on morphos
    arcade type usb joysticks or via adapter also work
    is to be tested
  • »15.09.22 - 07:59
    MoerBoer
    Posts: 239 from 2019/10/15
    I tried my old MBox2 (USB) a while ago, and it powers on, but nothing is picked up in MorphOS
    DigiDesign / Avid's older HW interfaces required specific drivers and aren't class compliant like the newer interfaces. That's why later versions of OS X don't work with those old HW interfaces.
    p.s. Even my Scarlett 2i2 which is class compliant doesn't work. If MorphOS could get a class compliant USB audio driver going it will open up a whole new world of audio interfaces that can be used.
  • »15.09.22 - 10:35
    Posts: 3319 from 2003/3/5
    It's 2.0 spec that isn't supported yet. USB audio 1.x compatible devices work.
  • »15.09.22 - 10:50
    Zergei72
    Anybody aware of a USB 1.0 Audio - Interface, that would work 100% on MorphOS ?
    Need 8 to 16 Mic Pre-Amps ; Options ?
    - Z -
  • »16.09.22 - 15:19
    Posts: 1090 from 2004/9/23
    You could check this thread
  • »16.09.22 - 17:11
