Problem on Quad G5
    NewSense
    Posts: 1618 from 2012/11/9
    Will it start from the MorphOS installation media? :-?
  • »26.06.22 - 03:25
    Posts: 2577 from 2003/2/24
    https://discussions.apple.com/thread/2589005
  • »26.06.22 - 05:36
    Posts: 1360 from 2004/2/8
    Papiosaur wrote:
    Any ideas please ?
    Thanks
    Sadly, it may be anything, ranging from a dying PSU to an overheated (and partially desoldered) U4 "KODIAK" kinda-northbridge chip on the back of the motherboard. If you have a known working PSU I'd reccomend starting with that.
  • »26.06.22 - 05:38
    Posts: 3336 from 2003/3/5
    Start by disconnecting power from the optical drive - if that helps, it’d point out to issues with the power supply.
  • »26.06.22 - 11:58
    Papiosaur
    Posts: 2612 from 2003/4/10
    Thanks jacadcaps for the tips.
    Seems to be my graphic card is out, i have changed it and now is ok (for the moment..).
    Radeon X1950Pro 256Mb replaced by a X1950GT 512Mb.
    Thanks to all for your help!
    New question: MorphOS recognize only 256Mb on my X1950GT, normal ?
    [ Edité par Papiosaur 26.06.2022 - 17:33 ]
  • »26.06.22 - 13:22
    zukow
    Posts: 661 from 2005/2/9
    yes, that's normal
  • »26.06.22 - 17:22
    Posts: 12557 from 2003/5/22
    > The 512Mb are used or only 256 are supported please ?
    Only up to 256 MiB VRAM are used/supported by MorphOS.
  • »27.06.22 - 09:32
