G5 and activate two monitors option
    Posts: 3278 from 2003/3/5
    It would help if you told us which G5 it is and which graphics card you are using exactly (a screenshot from GraphicsBoards would work). Most likely the answer will be: "you can't do this with your current card and 3.17", though.
  • »19.05.22 - 11:25
    I'm afraid you dual head isn't supported on this card at the moment.
  • »19.05.22 - 11:45
    Papiosaur
    Posts: 2540 from 2003/4/10
    ok, thanks for your answer.
    A graphic card is supported on MorphOS 3.17 or 3.18 for the moment ?
    I have a X1950 Pro work with the two display too.
    i hope these graphic cards will be supported soon :-)
    [ Edité par Papiosaur 19.05.2022 - 15:52 ]
  • »19.05.22 - 11:52
    Newcgen
    Posts: 10 from 2022/4/11
    Papiosaur wrote:
    Hi jacadcaps,
    it's a Quad with X1950 GT
    Could you show the output of your Open Firmware printenv command?
    I have the same video card. It works with PC.
    MorphOS boots with the original Radeon, but won't boot with X1950 GT.
    Does the X1950 GT requires a special settings?
    [ Edited by Newcgen 19.05.2022 - 18:00 ]
  • »19.05.22 - 11:59
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Papiosaur wrote:
    Hello all,
    i have a G5 with graphic card with two external out DVI, i have 2 screens with the same display
    How to have two differents screens please ?
    I have a Radeon 9650 and currently just use this method to open particular programs on the second screen/monitor:
    https://library.morph.zone/Tips_and_Tricks#How_to_Open_MUI_Programs_on_Their_Own_Screens
    The mouse movement between the two monitors has been improved in the recent update so that you do not need to select the screen to switch back and forth. I open several programs by default on the second screen/monitor.
    [ Edited by IKE 19.05.2022 - 07:50 ]
    IKE
  • »19.05.22 - 12:46
    Papiosaur
    Newcgen a écrit :
    Papiosaur wrote:
    Hi jacadcaps,
    Hi Newcgen,
    sorry, i didn't have access to Open Firmware with these two graphic cards...
  • »19.05.22 - 17:29
    Papiosaur
    IKE a écrit :
    Papiosaur wrote:
    Hello all,
    Hi IKE,
    could you show me the external screen option please ?
    How to configure it please ?
    I will try with my other G5, maybe...
  • »19.05.22 - 17:38
  • IKE
    IKE
    Papiosaur wrote:
    Hi IKE,
    I emailed you some screenshots, but basically:
    Create a new external screen in main MUI prefs. Point the MUI program to that screen in the program's prefs (foreign public screen).
    IKE
  • »19.05.22 - 18:21
    Posts: 2209 from 2003/2/24
    Papiosaur wrote:
    How to define left and right screen please ?
    Read the last chapter (Usage) and follow the link it points.
  • »20.05.22 - 11:59
