Overclocking Pegasos 1, G3
    Posts: 471 from 2019/5/9
    Hello,
    please, can somebody advice me how overclock Pegasos 1 with G3 (750CXe) ?
    I found here few topics about G3 overclocking, but they are old, links are not works and original authors are not logged here for several years:
    FS: Pegasos I G3@700 MorphOS Keyfile 768MB April2 complete
    Overclocking the 750CXe (G3) CPU boards
    Overclocking your G4
    It will be great, if somebody have schemes or other stuff.
    Many thanks!
  • »04.10.21 - 04:38
    Posts: 1372 from 2010/1/6
    Ask user DJBASE! Hie did it für a PEG2-G4. Maybe he nows it also for G3.
    For G4 only a new bridge has to be soldered on CPU-Board (see pic below). Don't know on G3.
  • »04.10.21 - 05:48
    Thank you! I will contact him.
    But regarding the picture I am afraid, that G3 and G4 CPU cards are different.
    As I know, CPU cards are the same for Pegasos 1 and Pegasos 2, only difference is in FSB frequencies ( Peg1 100MHz, Peg2 133MHz) so if there will be scheme for Peg 2 G3 multiplicator, it will be great.
  • »04.10.21 - 06:12
    Posts: 899 from 2003/3/4
    Historically it was never done much, both because the G3 CPU overlocked is still pretty poor, but because the April chip is a major performance brake that'll undermine anything you do anyway - and that's if it doesn't screw up timing and cause Articia lockups.
    Probably best not to bother.
  • »14.10.21 - 14:21
    Finally, I got scheme of PLL of Pegasos 1 G3 CPU card. I tried overclocking.
    Technically it is fine, unfortunatelly with higher multiplicator settings (x6.5, x7.0) Open firmware sets FSB frequency to 66MHz (was 100MHz). So, no speed increase is possible with April 1 fix. Theoretically April 2 can do better, but I have no one.
    I have one question regarding USB2.0 card:
    I tested two VIA and NEC USB2.0 cards, they works with Pegasos2 and Sam440ep-flex OOTB.
    But inside Pegasos 1 April 1 NEC never works, and VIA behaves randomly:
    VIA either don't work: (with this message in USB stack log)
    6:11 pm| 0-hub.class: Detected device 'USB 2.0 Hub [MTT]' at port 4. I like it.
    6:11 pm| 0-hub.class: Hub has added 1 device(s). That'll be fun!
    6:11 pm| 0-hub.class: Hub with 4 ports successfully configured.
    6:11 pm| 0-hub.class: I'm in love with hub 'USB 2.0 Hub [MTT]'.
    6:11 pm| 0-hub.class: Oh no! I've been shot! Arrggghh...
    6:11 pm| 0-hub.class: My death killed device 'USB 2.0 Hub [MTT]' at port 4!
    6:11 pm| 0-hub.class: Time to get rid of 'USB 2.0 Hub [MTT]'!
    6:11 pm| 0-hub.class: Time to get rid of 'PCI Root Hub Unit 1'!
    6:11 pm| 0-poseidon.library: Removed hardware pciusb.device/1. Bye bye!
    or VIA works poorly: USB2.0 is fine, but graphics speed is very reduced: Copy-to-VRAM speed is reduced from 81MB/s to 26MB/s!
    Interesting is, that both above cases occured with the same PCI+AGP cards configuration.
    Is here somebody with Pegasos 1? Can you tell me your experinces with USB cards please?
    [ Edited by sailor 19.02.2022 - 12:55 ]
  • »19.02.22 - 10:53
    Just look here: http://www.amiga-news.de/de/news/AN-2022-02-00069-DE.html
    Need to translate it!
  • »20.02.22 - 17:01
    Yes, it is all the story with my Peg1. Some questions is still unanswered ;-)
  • »20.02.22 - 17:41
    Primax
    Posts: 208 from 2021/7/2
    @NewSense
    No need to "garble" our news item, there is always an English-language version ;)
    https://www.amiga-news.de/en/news/AN-2022-02-00069-EN.html
    Of course we also wrote an article about sailor's great comparision of graphic cards for Sam440ep-flex (linked in the news), but there I was reproved: I should not offer automatic translation because everybody wants to use his favourite translator...
  • »21.02.22 - 12:50
    Ohh - did'nt recognize (moebius loop :-) )
  • »21.02.22 - 14:34
    Goodman
    Posts: 115 from 2006/8/2
    Here my brief experience with April2:
    Time ago I had a VIA it worked ramdonly, ALi and NEC don't work at all.
    Be careful with graphics cards which are listed as "compatible".
  • »03.03.22 - 17:22
    Thanks,
    it looks that ArticiaS with April 2 have the same or very similar issues.
    Oh, April is not May, and May is not Marwell ;-))
  • »04.03.22 - 05:07
    Posts: 2209 from 2003/2/24
    Hmm... I have Radeon 9100 and some Via USB 2.0 card in my Peg1 with April2 fix, and although I haven't used the USB much at all in the last years, it used to work fine back then. Graphics memory seems to write 74 MB/s now, I guess it's ok...
  • »04.03.22 - 15:37
    @jPV
    That's nice!
    At least some combinations gfx+USB works.
  • »04.03.22 - 16:47
