Bluetooth and MorphOS
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hello,
    i would like to test a Keyboard in Bluetooth mode.
    I have a receiver with a class Bluetooth reconized in MorphOS USB Prefs but no binding class
    What is the procedure to connect it please ?
    Thanks ;-)
    [ Edité par Papiosaur 24.06.2021 - 14:40 ]
  • »24.06.21 - 09:42
    Papiosaur
    Thanks a lot Andreas_Wolf!
    No receptor has possibility to save prefs in his hardware instead of OF ?
    Is it possible to boot on MacOX installed on a USB key or maybe a live CD to configure Bluetooth prefs in OF ?
    [ Edité par Papiosaur 24.06.2021 - 15:27 ]
  • »24.06.21 - 11:15
    MoerBoer
    Posts: 240 from 2019/10/15
    If you figure this out please let me know.
    I was actually last night trying to install 10.4 on an external USB but the installer refused to install on it irrespective of how I formatted it or partitioned it.
    My wireless Apple keyboard worked great with MorphOS after I paired it with OSX. Problem is I later formatted the machine to only have MorphOS on it and after I replacted the PRAM battery I lost connection to the keyboard again and I have no way of getting it back unless I reinstall OSX on the SSD and the reinstall MorphOS again ( Which I *REALLY* don't want to do )
  • »24.06.21 - 12:00
    Posts: 3336 from 2003/3/5
    MorphOS does NOT support Bluetooth. I can only suggest that you return the USB dongle. You don't need it on OSX, it will NOT work on MorphOS.
  • »24.06.21 - 13:55
    Posts: 12557 from 2003/5/22
    > I have bought this receptor: [...]
    > Question: i need a receptor like this or not ?
    I think the OpenFirmware-based pairing only works with built-in Bluetooth.
  • »24.06.21 - 13:57
    That's correct. OF only handles the Bluetooth of AirPort cards.
  • »24.06.21 - 14:08
    Posts: 1360 from 2004/2/8
    Find an external FireWire harddrive. I believe you should be able to install OSX on it and easily boot from it any time you wish to.
  • »24.06.21 - 14:25
    MoerBoer
    Oh, that's cool!
    Now to try and source that ... Thanks. I'll give an update if I ever get one.
  • »24.06.21 - 14:43
    Posts: 611 from 2003/4/11
    MoerBoer schrieb:
    Oh, that's cool!
    Try to get hold of an
    OWC Mercury on-the-go Pro
    external case
    Great addition if you want to boot from an external firewire SSD and/or want to do backups for MorphOS. Not exactly cheap but great add-on for my PPC machines ...
    Make sure to get the FireWire+USB3 version and not the USB3-only one ...
  • »24.06.21 - 17:25
    NewSense
    Posts: 1618 from 2012/11/9
    I use an Iomega MiniMax (Model 33671 and 34940) with OSX 10.4.11 (Tiger) on them, as they both have USB2 and Firewire on the enclosure interfaces. Though I've also got an Iomega Extreme (HDD1H) and a few laptop portable HDD enclosures (LPHD160-C) which also have both USB and Firewire built-into the interfaces. So, these too are suitable to install Mac OSX onto as though it was directly connected internally with it being Firewire connectable, which you have to connect this way for it to boot/dual-boot MacOSX-MorphOS. I think I've even got an old Formac HDD USB/Firewire enclosure that I could use if I needed to. Each one of these enclosures will allow you to boot Mac OSX and then allow you to "pair" a bluetooth device so that when you boot with MorphOS using the same logicboard/hardware you can access the bluetooth device even though you are using MorphOS.
    I daily use an Apple A1016 bluetooth keyboard for MorphOS, in fact I'm using it right now, so I know it works OK, which I "paired" through Mac OSX with the same hardware in my MacMini, just using an external HDD that was attached via Firewire that already had Mac OSX installed on it.
  • »24.06.21 - 19:26
    Papiosaur
    I propose now an External box FireWire/USB on MorphOS Store ;-)
    It's expensive but i didn't find lower price except for an order of 100 units...
    @jaca: thanks for your answer!
    [ Edité par Papiosaur 25.06.2021 - 18:18 ]
  • »25.06.21 - 03:01
    MoerBoer
    Do then also require a firewire 800 to 400 convertor?
  • »25.06.21 - 04:09
    MoerBoer
    If z970mp can get this working as a live boot system, it should solve the problem elegantly with just burning a boot DVD.
    MacRumors
    [ Edited by MoerBoer 25.06.2021 - 09:34 ]
  • »25.06.21 - 04:16
