Powerbook without screen and MorphOS ?
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hello,
    i have a Powerbook with a broken screen.
    It will be possible to have MorphOS use only external DVI port and remove broken screen ?
    I launch MorphOS on it, if internal connector is connected to original powerbook screen i have MorphOS show on external screen.
    If i disconnect the original powerbook screen before startup, i have nothing on external screen.
    If i disconnect the original powerbook screen after startup, i keep MorphOS on external screen.
    I would like MorphOS on external screen removing powerbook screen, is possible ?
    Any ideas ?
    Thanks ;-)
    [ Edité par Papiosaur 19.05.2021 - 15:15 ]
  • »19.05.21 - 11:14
    Posts: 1361 from 2004/2/8
    Any ideas ?
    You'd like to get rid of the whole display (just rip it apart from the rest of computer) and have only the main body plus external monitor, or just dim the monitor so the broken display won't disturb you?
    If the latter, then you could just unplug the inverter from the display. It will kill the display backlight so nothing would be seen on the (still connected) display.
    If the former (and the ribbon cable has to be connected) then some research would be needed (what signal does the display send back to the motherboard that it's present), and you'd have to find a way to simulate it.
  • »19.05.21 - 11:30
    Papiosaur
    Hi koszer,
    yes, i would like to remove completly the screen :-)
    I have just tested, it work with only nappe and printed circuit board of the powerbook screen removed but i would like morphos show on external without that :-)
    But i think it's a hardware problem...
    [ Edité par Papiosaur 19.05.2021 - 15:42 ]
  • »19.05.21 - 11:41
    You could always isolate and fit the needed circuitry inside the PowerBook case :)
  • »19.05.21 - 12:42
    NewSense
    Posts: 1618 from 2012/11/9
    There is a lid closing switch in the front edge of the palmrest/keyboard, in the base of the Powerbook case, that usually triggers if the lid is closed, and this is probably what you'd need to ensure indicates to (fools/tricks) the system that the lid is shut (even though it would have been removed) so that the external display gets activated when you switch on/boot MorphOS - if I understand you correctly. 8-D
    Which model of Powerbook is it anyway?
    The LCD displays are quite easy to fix/remove/replace, and often not that expensive, especially if they are the low-resolution model.
  • »19.05.21 - 16:42
    It's not that easy to obtain a 15,2 inch display for PowerBook. It's much easier to find a 17 inch one though, as it's got pretty much standard diameter.
  • »19.05.21 - 17:38
    NewSense
    @ kozser - I've always been able to find one when I needed one, and usually at a great price, though I haven't changed one-out for a few months, but I don't know if it is 15" (15.2") or 17" at the moment, as papiosaur hasn't specified which one he wants to do this project/screen issue/fix with, as yet.
    I prefer to have a working screen as part of the Powerbook(s) I own, but it's a matter of personal preference, and competence/confidence it can be undertaken successfully, I suppose. :-)
  • »20.05.21 - 03:09
    A quick search on eBay for LTN152W6 gave me a few results, but the cheapest one is for 35+18 USD. With any luck you could find a working PowerBook for that price.
    But if you're patient enough I guess you could check every now and then and eventually get one for - I don't know - 15 EUR?
    But we're strolling away from an interesting hardware project that Papiosaur started. And he made me wonder if it would be possible to fit a G4 PowerBook into an iMac G5 case :)
  • »20.05.21 - 03:31
    NewSense
    koszer wrote: [... And he made me wonder if it would be possible to fit a G4 PowerBook into an iMac G5 case :-)
    Ooh, that's a novel idea. 8-)
  • »21.05.21 - 03:26
    Posts: 611 from 2003/4/11
    While this is probably a fun experiment, I still would go for the iMac G5 with the original ingredients instead if I wanted to use MorphOS on it ... :)
  • »21.05.21 - 19:38
    That goes without saying. Nevertheless, I do have a spare iMac G5 case (from a 1,8 GHz version with blown capacitors) stashed on the topmost shelf of my closet and should also find a working A1095 PowerBook mobo a few shelves lower.
  • »22.05.21 - 03:43
