Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Hardware
White screen on PowerMac G4 1GHz
Papiosaur
# 1
Posts: 2559 from 2003/4/10
Hello,
i have bought a PowerMac G4 monoprocessor at 1GHz but when i launch MorphOS CD via ALT menu i have a white screen...
Any ideas ?
Thanks for your return
[ Edité par Papiosaur 14.05.2021 - 16:26 ]
papio-software.com
Ko-fi
www.meta-morphos.org
www.morphos-storage.net
14.05.21
12:20
MorphOS Developer
Posts: 3296 from 2003/3/5
Which model is it exactly? Did you try USB boot? My first bet would always be on the CD drive not working.
14.05.21
13:10
Papiosaur
# 3
It's a MDD with a single processor G4 at 1GHz.
MorphOSCD is reconized under MacOS
[ Edité par Papiosaur 14.05.2021 - 17:43 ]
papio-software.com
Ko-fi
14.05.21
13:39
MorphOS Developer
That does not mean anything, really. Try USB.
14.05.21
13:50
Papiosaur
# 5
Don't work via USB too.
OF write Loading ELF
DO-QUIESCE finished_
and nothing...
papio-software.com
Ko-fi
14.05.21
14:08
MorphOS Developer
Did you check which graphics card it has? :)
14.05.21
14:27
Papiosaur
# 7
Oooohhh.....
I go to change this bab NVidia graphic card...
Thanks Jacadcaps
[ Edité par Papiosaur 14.05.2021 - 19:38 ]
papio-software.com
Ko-fi
14.05.21
14:33
