Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Hardware
Brightness on IMac G5
Papiosaur
# 1
Posts: 2572 from 2003/4/10
Hello all,
is it possible to adjust brightness level on IMac G5 please ?
Thanks for your answer!
papio-software.com
Ko-fi
www.meta-morphos.org
www.morphos-storage.net
21.03.21
08:03
BatteMan
# 2
Posts: 290 from 2003/2/24
You can do it in "Monitors" preferences.
Edit your monitor and, in the second tab, you can adjust brightness, gamma and contrast ;)
21.03.21
19:22
MorphOS Developer
Posts: 3311 from 2003/3/5
I think he meant adjusting the backlight level. That is not currently possible on MorphOS. Adjust it on OSX, reboot and it should keep it.
21.03.21
19:25
