Wifi causing cpu spikes every 2 minutes.
    Mozzerfan
    Posts: 105 from 2016/10/5
    Hi all.
    I have a weird problem on all my systems that use wifi.
    Every 2 minutes I get a cpu spike for a second caused by the background task
    background cli [mossys:Net/b43].
    Cpu usage spikes to 100% for a second,and then goes back to normal.
    But it happens every 2 minutes.
    I noticed it, because it causes lag in FPSE when I don't put wifi offline.
    Anyone else has got this problem? Or is it normal behaviour.
    I tried connecting to another Wifi access point,but this behaviour is the same.
    Edit: Forgot to mention that it also happens when I boot from the morphos CD.
    [ Edited by Mozzerfan 10.12.2020 - 13:44 ]
  • »10.12.20 - 11:40
    Posts: 3296 from 2003/3/5
    This, unfortunately, is normal. Wifi needs to recalculate things periodically and we do all this in software.
  • »10.12.20 - 12:29
    Mozzerfan
    OK Thank you for the reply.
    I was worried something was wrong.
  • »10.12.20 - 12:45
    Posts: 141 from 2017/8/6
    Might be a good point for optimizations, at least. ;-)
    Probably way down on the todo list, anyway...
  • »10.12.20 - 19:00
    Templario
    Posts: 556 from 2012/4/28
    Thank you for the explanation, now I understand the problems with my PowerBook and its wifi.
  • »11.12.20 - 15:38
