Smartphone Internet sharing on X5000
    Posts: 20 from 2018/4/2
    Hi everyone,
    This morning i have discovered at wake up that i have no internet connexion, my provider cannot come before thursday next week. So i need a work around solution to my issue.
    i have no problem to share my smartphone connexion using wifi on the powerbook. For the x5000 i have no wifi card so i need another way to share. i have tried directly using usb it works on fienix but not on morphos.
    Any idea ? Maybe it is not possible ?
    thanks
    additional question which wifi card can i use on the x5000 ?
  • »07.11.20 - 11:22
    Posts: 141 from 2017/8/6
    Dunno if MorphOS can do it but Mac OSX on the Powerbook can forward your Wifi connection via Ethernet with internet sharing.
    https://stackoverflow.com/questions/40834689/share-internet-connection-between-macos-x-leopard-and-windows-10
    [ Edited by amifrog 07.11.2020 - 13:41 ]
  • »07.11.20 - 11:31
    Posts: 1360 from 2004/2/8
    I guess you should buy a compatible PCIe WiFi card or connect some wireless router through Ethernet and configure it to use your phone shared WiFi.
    I guess your best bet is a card proven to work with PowerMac G5 PCIe:
    older Atheros pcie based WIFI or realtek 8168
  • »07.11.20 - 13:47
    Posts: 902 from 2003/3/4
    A little, relatively cheap travel router or WAP is handy for times like these. They either connect phones, dongles, or insert SIMs, or all of the above, and usually have an ethernet connection.
    Even better to have that functionality in your main router itself, so you can use the phone as a backup connection. Many routers do allow this. Check yours: if it has a USB socket, then it might do too.
    Although as a warning: compatibility is be heavily dependent on the phone manufacturer (Apple in particular hate their users being able to do useful things) and the cellphone provider. Many providers specifically ban tethering and will send you angry texts.
    Also as a warning: it is REALLY easy to go over your data limit and cost yourself a small fortune when tethering.
  • »07.11.20 - 14:51
    thanks
    i have 200go on my phone so no matter with that :)
    the older router could share connexion from the usb the new one not ....
    i am not really happy with this new device ...
    i will try to find a wifi card on ebay
  • »07.11.20 - 15:58
    Posts: 1390 from 2010/1/6
    Why dont use a WLAN-Minirouter like this:
    https://www.reichelt.at/at/de/wlan-router-2-4-ghz-150-mbit-s-tplink-tl-mr3020-p118522.html?PROVID=2807&gclid=EAIaIQobChMI0Lyl4Yrx7AIVVj5gCh3HaQiLEAYYBiABEgKGxPD_BwE
    Can be used as bridge from your mobilephone-Hotspot to ethernet.....
  • »07.11.20 - 16:43
    Posts: 12552 from 2003/5/22
    How should this help with a WiFi-less X5000?
  • »07.11.20 - 17:40
    Intuition
    Posts: 1116 from 2013/5/24
    The PowerBook can share the phone's data connection via WiFi to the X5000 through an Ethernet cable.
  • »07.11.20 - 19:18
    Thanks, makes sense. I somehow managed to read over the part where he mentioned his PowerBook ;-)
  • »07.11.20 - 19:23
    That's why you can and should have a dual boot system in the first place: to complement MorphOS with the emergency tools and usability that comes with billions of use hours ... and $.🤪
  • »07.11.20 - 19:51
    Thanks everyone
    I have a lot of systems and devices at home
    My goal is to proove that you can work with Morphos everyday :)
    Tplink routeur purchased now i have to wait tuesday
  • »08.11.20 - 09:08
