Problem with DualShock V2 PS4
    Papiosaur
    Posts: 2572 from 2003/4/10
    Hello,
    i have a DualShock V2 PS4 model CUH-ZCT2E wireless controller.
    I test it with last version of OpenBOR and with analog stick only diagonal and left work, other directions are buggy any idea ?
    When i want use direction button to active this variable:
    SETENV LOWLEVEL_XBOX_USEHATSWITCH 1
    Diagonal directions don't work...
    It will be possible to configure each joystick to create a specific class ?
    Thanks a lot ;-)
    [ Edité par Papiosaur 10.04.2020 - 11:10 ]
  • »10.04.20 - 06:42
    Posts: 3311 from 2003/3/5
    I'll see if I can borrow one from work as soon as life returns to normal and my work office is open again...
  • »10.04.20 - 12:07
    igracki
    Posts: 469 from 2003/2/24
    Same here, I only can walk to the upper/lower right (diagonal) by pushing the analog stick to the upper/lower right. If I push the stick to the right I walk to the left.
    Tested with OpenBOR and GIJoe Demo.
    If I set the envvar, I can assign the directional buttons and walking to each direction is working fine.
    I also tried MultiRacer, and with the envvar set I can use the directional buttons and L1 and R1 in the controls menu.
    But without the envvar I can setup the analog stick for accelerate, brake, left and right but the directional buttons and L1,R1 are not recognized!
    And steering with the analog stick works good in this game.
    So I think the bug with handling the analog stick is in SDL!?
    Would be nice if one could use both, the directional buttons and the analog stick at the same time, also the right stick and L2, R2.
  • »11.04.20 - 12:10
    igracki
    I could just test a wired xbox controler, and the left analog stick ist working very well with GIJoe in OpenBOR!
    So maybe its not a bug in SDLs analog handling, but in xbox360.class!?
  • »11.04.20 - 12:18
    beworld
    Posts: 670 from 2010/2/10
    Have you test to put this :
    (Extract Release Note 3.12)
    Libs/Lowlevel
    Prefer left analog stick to left hat switch. Can be reversed by setting LOWLEVEL_XBOX_USEHATSWITCH environment variable. As the result, games using lowlevel.library will treat the left analog stick of an Xbox360 compatible gamepad as the main joystick
    I test with it and working well with my PS4 controller with xbox360.class.
    My MOS ports
  • »11.04.20 - 13:35
