Search graphic card compatible MorphOS for Quad G5
    Posts: 141 from 2017/8/6
    Have a look over there:
    https://www.morphos-team.net/hardware
  • »25.01.20 - 11:31
    Papiosaur
    Posts: 2612 from 2003/4/10
    Thanks amifrog for the link.
    I know graphics cards compatible but i search one work on Apple Quad and MorphOS (tested).
    I have bought 4 "compatible" cards but no success.
    The card must be specific Apple or flashed for Apple...
  • »25.01.20 - 12:16
    It only needs to be Apple-flashed if you want to run Mac OS with it.
  • »25.01.20 - 12:41
    Posts: 12557 from 2003/5/22
    ...or access OpenFirmware or the built-in boot menu. Another possibility is to use two graphics cards where one is just for MorphOS.
  • »25.01.20 - 12:53
    Thanks for clarification.
    Here is the thread about it, btw.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12716&forum=11
  • »25.01.20 - 12:54
