Problem with MorphOS on Quad G5
    zukow
    Posts: 661 from 2005/2/9
    does powermac works? does cdrom load cdrom with morphos?
    check if caps lock is working
  • »09.11.19 - 20:16
    Posts: 1360 from 2004/2/8
    Is there a boot chime? Does the machine start with default nVidia card?
  • »09.11.19 - 20:28
    Papiosaur
    Posts: 2612 from 2003/4/10
    There is a boot chime with nvidia card but no with Radeon card...
    Quad works under MacOS and nvidia card
    CD-Rom drive is ok, MorphOS start on CD but stop...
    @zukow : capslock key ?
    [ Edité par Papiosaur 10.11.2019 - 06:02 ]
  • »10.11.19 - 04:00
    Posts: 2577 from 2003/2/24
    Being able to toggle the CAPS-LOCK LED means that the G5 got to the point of starting basic USB.
    You could also keep in both GFX-card to see if your thrown back to the OF "no boot device logo" (sad face).
  • »10.11.19 - 05:17
    Posts: 1390 from 2010/1/6
    Are you able to enter OpenFirmware-console useing the Radeon-card?
    If yes, you may boot MorphOS manually:
    >boot cd:,\mac_ppc64\boot.img
    Then you can see what happens: Is kernel loading? Does Morphos-System load?
    If you cannot enter Open Firmware, your Radeon (PC-flashed card?) is not recognized by OF and if MOS won't boot, you cannot see what's the reason for.
    Very strange that there is no boot-chime with radeon-card. If this card fits to physical specs of slot (electricaly) then there should be a chime, even if card is not initialized by OF.
  • »10.11.19 - 06:29
    Posts: 611 from 2003/4/11
    Is the extra pciE G5 power cable properly connected to the X1950 graphics card ?
  • »10.11.19 - 10:46
    Posts: 12557 from 2003/5/22
    > Radeon-card? [...] If you cannot enter Open Firmware,
    I guess it's a non-reflashed x86 ROM card, so no OpenFirmware access.
    > If this card fits to physical specs of slot (electricaly) [...]
    Isn't PCIe physically and electrically compatible over all versions, so that a PCIe v1 card works in a PCIe v4 slot and a PCIe v4 card works in a PCIe v1 slot?
  • »10.11.19 - 11:27
    zukow
    Check card in other PCI slot and maybe try with other card. 1950XT / 1900XT cards are preffered as i mentioned in HOWTO thread.
  • »11.11.19 - 08:22
    Papiosaur wrote:
    Hello,
    i would like to boot MorphOS on my Quad G5 with a Radeon X1950Pro but don't start...
    Any ideas please ?
    I have the same issue with Dual Core 2,3 GHz and two of my Radeons X1950. I'm yet to test the third one. I guess you have to test a card that's "MorphOS compatible" based on zukow's pictures.
  • »11.11.19 - 12:52
    Posts: 3336 from 2003/3/5
    X1950 Pro here - bought 2 weeks ago. Works fine. You need to make sure you've connected the display cable to the right DVI port though.
  • »11.11.19 - 14:08
