Installing MorphOS 3.12 on PowerMac G5
    Posts: 3 from 2018/8/4
    Hello everybody,
    I just bought a PowerMac11,2 DP 2GHz and I'm trying get MorphOs 3.12 working on it.
    I already have a G4 MacMini with MorphOs 3.11 working perfectly.
    The first thing I did was to buy an ATI Radeon card for the G5 and it worked, I had no problem installing MorphOS 3.12.
    But I have 2 issues to solve now:
    1) The Gigabit Ethernet card is not detected. Trying to figure out why.
    2) I does not come with a WIFI Card, so I need to know what card can I buy to have that working. ¿Any suggestions?
    Thanks for your help and I really appreciate all the time you spend on updating MorphOS.
  • »04.10.19 - 11:39
    Posts: 2220 from 2003/2/24
    Do you mean 11,2 Dual Core (not DP) or 7,2/7,3 DP (Dual Processor)?
  • »04.10.19 - 12:54
    Sorry, 11,2 Dual Core
    https://everymac.com/systems/apple/powermac_g5/specs/powermac_g5_dual_2.0.html
  • »04.10.19 - 13:39
    asrael22
    Posts: 453 from 2014/6/11
    So does this mean that MOS 3.12 now supports PowerMac11.2 a bit more?
    I remember there was the problem with the fans spinning at full speed on this machine.
    Manfred
  • »05.10.19 - 09:21
    Posts: 12557 from 2003/5/22
    > a bit more? I remember there was the problem with the fans
    Yes, see release notes.
  • »05.10.19 - 13:31
    asrael22
    OK, cool.
    Could I just move the the SD drive from a 7.3 to a 11.2 after installing MOS 3.12?
    Manfred
  • »05.10.19 - 14:51
    Posts: 1360 from 2004/2/8
    asrael22 wrote:
    OK, cool.
    Manfred
    Yep, that should work (of course except for the licence key).
  • »05.10.19 - 15:01
