Will we see iMac G5 support?
    Elowan
    Posts: 214 from 2011/4/18
    ... or does it already work?
    I mean, PowerMac G5 seems to work, but no mention of iMac G5´s ?
    kind regards
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »01.03.16 - 11:30
    Posts: 2577 from 2003/2/24
    Has been demoed some years ago (even got it installed on mine ;) ) but AFAIK it was never developed to full useabilty.
    We are talking bout the iSight iMac that shares a lot of HW with the PCIe PowerMac_G5.
  • »01.03.16 - 14:17
    connor
    Posts: 650 from 2007/7/29
    What is holding it back? I read of some components that are tricky. Do you know which ones and why? The iMac would be almost as fast as a PowerMac G5 but not that fat and noisy.
  • »01.03.16 - 16:32
    Lack of motivation/resources ?
    Other priorities ?
    Dunno, but I sure know that the version I have(years old) isn't anything I would want to use day in day out.
  • »01.03.16 - 17:36
    connor
    Is it unstable or slow or are drivers missing?
  • »01.03.16 - 18:37
    Elowan
    Hmmm, so we talk about the 20" late 2005 models, right?
    Cheers
  • »01.03.16 - 19:22
    Posts: 12557 from 2003/5/22
    Yes, see that thread:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9034&forum=11
  • »01.03.16 - 21:29
    Posts: 2 from 2016/4/24
    Hello
    I had also one of These models. Its an powermac8.2. could it be in The Near future possible that Morphos works on this Mac?
  • »24.04.16 - 16:28
    Posts: 1360 from 2004/2/8
    Could be. I say there's some 50% probability it will. Alas, there's nearly 50% probability it won't. Anything else is just a speculation.
  • »25.04.16 - 08:03
    Posts: 611 from 2003/4/11
    The iMac 20" late 2005 models are PowerMac12,1 as described in
    http://www.everymac.com/systems/apple/imac/specs/imac_g5_2.1_20.html
    and not PowerMac 8,2 as described in
    http://www.everymac.com/systems/apple/imac/specs/imac_g5_2.0_20.html
  • »25.04.16 - 11:59
    deka
    Posts: 136 from 2013/2/12
    > Other priorities ?
    Does it really make sense to put more work to this line?
    There are many different range of supported computers. Everybody could find a supported model for his/her budget.
    I think the change to current HW is more reasonable, than support the n'th model from the same class.
    But, I also don't know too much, what the guys are doing nowadays.
  • »25.04.16 - 12:24
    Posts: 2094 from 2003/6/4
    > Other priorities ?
    Support for one g5 imac model may be worth the effort. They are not as bulky and energy hungry as the G5 Powermacs, but offer quite a bit more than e.g. the G4 mac minis (more cpu power, more RAM, faster hdd and more potent gfx). Generally my stance is to put all efforts to x64, but if a G5 imac would be supported I could well imagine to get one myself.
  • »25.04.16 - 16:35
    Yes, this is also my mind. I like the clean desk and power on screen. Maybe the developer are with us. I have a lot old amiga games and want play with my children. Or could anybody a similar hardware recommend that works?
  • »25.04.16 - 18:03
    What is MorphOS' advantage regarding running old Amiga games?
    You can use any decade-old x86 hardware with JIT-enabled UAE.
  • »25.04.16 - 20:05
    Obviously ;)
  • »04.10.19 - 10:40
    > Obviously ;)
    Anything obvious (missing or broken functionality, non-supported components, stability issues etc.) that would explain why the public MorphOS 3.12 release runs on it only inofficially?
  • »04.10.19 - 11:55
