Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Hardware
msata+msata to 2,5 IDE on Powerbook G4
kickstart
# 1
Posts: 227 from 2009/4/28
Hi!
Im trying to instal a 32gb msata disk with a msata to ide adaptor, Morphos dont recognize the disk, anyone have another of this msata disks on a Powerbook G4?... I need to prepare msata for first use?
Thanks.
09.10.18
17:54
Templario
# 2
Posts: 556 from 2012/4/28
Do you know if the Power Book recognizes this drive?
Because this is the problem in macs when you change the hard diks.
09.10.18
18:10
kickstart
# 3
OSX Leopard install disk boot but installation dont start, a grey prohibition signal image appears.
09.10.18
18:56
Templario
# 4
Uff, I think that you have the problem the mac controller drives doesn't work.
09.10.18
19:30
kickstart
# 5
Controller problem? IDE hard disks runs fine.
09.10.18
19:56
# 6
MorphOS Developer
Posts: 1090 from 2004/9/23
Die Problem is probably related to Master/Slave. Usually thats done by Firmware of 2.5" drives as there are no jumpers.
If I recall right, we had the same issue on a geit@home meeting and the solution was to put the SSD to the CDROM port.
Probably polluks knows as it was his powerbook.
And just to be clear. There is not special init required when it fails, something is not compatible.
[ Edited by geit 10.10.2018 - 01:44 ]
09.10.18
21:43
kickstart
# 7
Then back to the original 2,5 IDE hard disk... thank you for all the answers.
10.10.18
14:55
