Posts: 847 from 2007/10/23
jacadcaps schrieb:
Powerbook 5,6 does not use keylargo for keyboard though - it is USB.
Aha, at least reslist shows the keylargo.resource
USBKeyLargo.cppQuote:
jacadcaps schrieb:
Since the issue also appears in the OpenFirmware prompts, it is indeed likely that this is a hw issue. As such it is not likely that this will get any workarounds on MorphOS.
Which OpenFirmware release? 5,
8 BootROM 4.9.6f0 works fine.
I never had this issue with macOS.
[ Editiert durch polluks 27.06.2018 - 21:37 ]Pegasos II G4: MorphOS 3.9, Zalman M220W · iMac G5 12,1 17", MorphOS 3.18
