Bluetooth file transfer; is it possible ?
    Desktop-Dynamite
    Posts: 12 from 2015/10/5
    Hello again,
    I have the A1134 iBook G4, which according to the specs here: https://everymac.com/systems/apple/ibook/specs/ibook_g4_1.42_14.html it should have a built-in bluetooth.
    Now is it possible to do file transfers and use bluetooth on MorphOS ?
    I cannot see any bluetooth related setting, nor icons.
    If yes, is there a guide which allows me to make use of bluetooth ?
    TIA
  • »21.12.17 - 00:28
    Cego
    Posts: 738 from 2006/5/27
    there is no bluetooth support in MorphOS and there will never be.
  • »21.12.17 - 04:51
    Posts: 2220 from 2003/2/24
    But in some occasions bluetooth devices can work, for example bluetooth mouse and keyboard do work with Mac mini (on MorphOS too) if they have been paired under OSX originally. I don't know if it's the case with any other models... maybe?
  • »21.12.17 - 05:33
  • Leo
    Leo
    Posts: 428 from 2003/8/18
    Never ? Why ?
  • »21.12.17 - 06:11
    Cego
    costs something like 10000 $ a year or so
  • »21.12.17 - 06:39
    amyren
    Posts: 219 from 2010/5/15
    Is that bluetooth licence fee required for free software as well?
    If yes, with all those free linux distros out there, who pays for those fees?
    If no, would it be possible to release the bluetooth drivers as a third party freeware addon?
    [ Edited by amyren 21.12.2017 - 11:37 ]
  • »21.12.17 - 09:36
    Posts: 3336 from 2003/3/5
    The companies that sell/sold BT equipped Linux hardware did pay for the license afair.
  • »21.12.17 - 10:14
    Posts: 655 from 2004/4/15
    So it should be no problem for Mos to support bt.
    The hardware manufacturer already payed the the licence fees and Mos just supports the
    build in hardware.
  • »21.12.17 - 11:36
    Well, does the Powerbook's BT work on Linux?
  • »21.12.17 - 11:38
    amyren
    Linux was only mentioned as a comment to the argument that BT never could happen on MorphOS due to the expensive yearly cost.
  • »21.12.17 - 13:19
    Posts: 2732 from 2003/2/24
    https://en.wikipedia.org/wiki/Bluetooth_stack
    http://www.bluez.org/about/
    https://www.bluetooth.com/membership-working-groups/membership-benefits
  • »21.12.17 - 17:48
  • Leo
    Leo
    I thought you needed a licence to create and sell a bluetooth device: I cannot find anything about writing your own bluetooth stack.
  • »22.12.17 - 08:59
    amyren
    Yes, it does!
    I just installed Lubuntu 14.04 onto my PowerBook A1138 model. At first it didnt seem to work, but after performing the update to 16.04 LTS it does work. I can now search and discover and pair BT devices from Lubuntu.
    And then I discovered that my logitech revolution mx BT mouse indeed does work under MorphOS. (thanks to jPV for that information).
    Pairing it when running Lubuntu first, but then it did not work in MorphOS. Then switched to OSX and paired the mouse again, and after that it did work under MorphOS directly.
    After pairing it in OSX, the BT mouse also works in the graphical boot menu. This means that the BT is enabled and paired even before the OS is loaded, and that probably explains why the mouse will work in MorphOS as well.
  • »01.06.18 - 06:08
    Posts: 902 from 2003/3/4
    That's interesting, I never heard of that before. It means the BIOS has some support for bluetooth directly, presumably because Apple were big on pushing wireless and were looking to avoid much of the issues with it not being available on early boot.
    It's probably doing it by wrapping the bluetooth input device to something else, i.e. making it look like a USB or PS2 device. MorphOS wouldn't even know it was dealing with BT.
  • »02.06.18 - 15:17
    Posts: 2577 from 2003/2/24
    That hidden BT in the AppleOF is news as least as old as the 1st release of MorphOS for the MacMini......
    Mapped as USB, but the mouse only supports 3 buttons, so no scroll wheel.
    When used with a magic mouse only 2 buttons, no gestures.
  • »02.06.18 - 15:39
