USB 3.0
    Hey, I was just comparing disk I/O on my laptop when I plug in an external USB hard drive.
    The throughput is over three times higher (almost four times actually) using a USB 3.0 interface then when using a USB 2.0 port.
    The chip used Renesas UPD720202, so basically its a latter day NEC component (most of us are using NEC based USB 2.0 cards).
    So, how hard would it be to develop USB 3.0 drivers for MorphOS?
  • »17.05.18 - 14:14
    Posts: 847 from 2007/10/23
  • »17.05.18 - 21:59
