bluethooth mouse
    serge
    Posts: 725 from 2003/2/20
    I bought tow bluetooth mices, very basic mices. They works proprely under windows, macos and linux but unfortunatly they are strange on morphOS. It seems they are fat, very fat. I feel a sort of delay.
    Is this problem known ? Does it exists a way to fix this issue?
    Thank you.
  • »15.08.16 - 08:44
    stephen_robinson
    Posts: 746 from 2007/4/22
    Are you using a Bluetooth keyboard as well?
  • »15.08.16 - 09:46
    serge
    Only mouse.
    Il have the same problem on my powermac G5 and on my Powerbook.
    Both have morphos 3.9
  • »15.08.16 - 09:58
    Posts: 847 from 2007/10/23
    By the way does a Magic Mouse work with MorphOS?
  • »13.05.18 - 20:11
    realstar
    Posts: 298 from 2003/2/24
    I have a bluetooth mouse that was not working under 3.9 that now works perfect under 3.10. I would try upgrading to 3.10 and see if it solves the problem.
  • »14.05.18 - 03:28
