Transfer 2.5
    Templario
    Posts: 555 from 2012/4/28
    I have problems with the new version of Transfer 2.5 (22.03.18) to upload files to my server host the program upload the files very slow even sometimes the program is freeze, I installed the new version of NetFS revised 1.1 and at least the program upload the files very slow before the update only was freeze. where is the problem? The system needs the TSL 1.0 protocol or the what?
  • »11.04.18 - 13:17
    beworld
    Posts: 668 from 2010/2/10
    i use it, to be sure i check Network Statistics, and Sent as OK
    so, in Transfert the transfert counter is wrong.
    Here, no freeze.
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »11.04.18 - 14:56
