MorphOS 3.9 on Sam460ex and Radeon HD 4650 - Jerky (Mouse)
    Posts: 2 from 2017/8/29
    Hello everyone,
    i want to try Morphos 3.9 on my sam460ex. The OS looks nice but every few seconds the mouse is stoping - then i must wait a little bit and so on and so on. The picture comes to the monitor via HDMI (resolution 1920x1080). Has anyone a idea what i can do to run Morphos smooth on this machine? On Morphos homepage they write that 3d acceleration dosn“t work with this card BUT the mouse jerks from the beginning when ambient screen is starting without any launched programms??
    Nice Greetings
  • »29.08.17 - 09:49
    Posts: 847 from 2007/10/23
    Did you try some other mouse or USB hardware?
  • »29.08.17 - 14:55
    Now I tried another mouse (no keybord or another usb-device was connected) - the same. :( I also tried it with booting from sd-card - also the same. :(
    [ Editiert durch franz87 30.08.2017 - 06:49 ]
  • »30.08.17 - 03:46
    Mozzerfan
    Posts: 105 from 2016/10/5
    Maybe you can try to disable enhanced display? This option is available in display prefs.
  • »30.08.17 - 04:11
    Posts: 1390 from 2010/1/6
    Maybe you need some changes in USB-Prefs for HID-Class. See picture!
    Play a bit with delay, NewMouseMode and Turbo_Mouse......perhaps it will change something.....
    Btw: How much workload is on the CPU during stuttering mouse? Also try a lower resolution.
    [ Editiert durch Amigaharry2 30.08.2017 - 13:09 ]
  • »30.08.17 - 04:38
    I would definitely try that.
    And the R700 drivers are due for an eventual upgrade, when that will be ready, I'm unsure of.
  • »30.08.17 - 08:44
