mldonkey
    klapdeur
    Posts: 132 from 2003/6/28
    help guys i just cant get any stuff from mldonkey i had it in front of
    me with the gui but when i search i get nothing do i have to install
    some server to connect or so ????
    can you guys help me out here???
    ps anyone knows anything about amigift project ???
  • »22.03.04 - 22:03
    Posts: 979 from 2003/6/28
    Do you connect from a DSL router? Check if you have opened the necessary ports, find it on http://mldonkey.berlios.de .
    Not needed to download servers list since that mldonkey does it automatically...
    I don't know too much about the project, but no new since a lot of time. Abandonated? Who knows...
    I could like a lot a nice looking and complete MUI gui (using mldonkey's gui protocol) for mldonkey, any are making it? I'm impatient waiting for it...
  • »23.03.04 - 06:11
    Jupp3
    Posts: 1193 from 2003/2/24
    Maybe your connection forces you to use proxy? If yes, you must specify its' address in configuration files...
    Connect to mldonkey with telnet.
    (Say, use Amtelnet and connect to 127.0.0.1) and enter commane "vm", that should list all servers, mldonkey is connected / is trying to connect to.
    Another thing you could try is "vma" which should list all servers defined in servers.ini
    btw, there are few servers.ini files supplied in bonus drawer, try copying one of them where mlnet executable is.
  • »23.03.04 - 06:38
