Posts: 561 from 2012/4/28
ASiegel escribió:
The error message you posted provides insufficient information. When you search for it online, it is also being mentioned in different contexts.
It appears that Yahoo try to fetch the file via AJAX but that fails for an unknown reason. As it works when you reload the page, I assume they use the history API to modify the URL (without a full page reload) in addition to invoking said AJAX call.
Have you tried spoofing as different browsers? Have you tested a much older OWB version just to see if this changes anything?
No I didn't tested in older browsers because the problem is new.
