What equipment to use the "audio in"?
  • kjb
    kjb
    Posts: 6 from 2007/12/31
    Hi.
    What equipment do I have to be able to record sound?
    My eMac does not support. Is PowerMac G4 and Soundblaster card can handle?
    Regards.
    Note, I use google translator
  • »18.10.16 - 07:27
    zukow
    Posts: 661 from 2005/2/9
    yep, soundblaster live is ok
  • »18.10.16 - 12:09
  • kjb
    kjb
    Will work under digibooster?
  • »18.10.16 - 14:17
    Posts: 12557 from 2003/5/22
    Yes, DigiBooster 2.x and 3.x use AHI.
  • »18.10.16 - 16:49
    realstar
    Posts: 298 from 2003/2/24
    Maybe check out my tutorial about recording on AudioEvolution 4.
    http://library.morph.zone/Recording_an_LP_with_Audio_Evolution_4
    It's about recording LPs but the concept is the same for any line level input source.
    [ Edited by realstar 19.10.2016 - 01:45 ]
  • »19.10.16 - 03:44
  • kjb
    kjb
    Thanks, next question - for Apple hardware I can use only PCI soundblaster, or usb too?
  • »19.10.16 - 14:16
