MorphOS 3.5.1 XBOX 360 official USB Controller No Class Resp
    XDelusion
    Posts: 602 from 2010/10/27
    Am I correct in thinking that the official XBOX 360 controller is now supported in MorphOS as a default?
    The problem I am having is that when I plug in my controller to the Efika (yes I still have it for now), it states that there is no class responsible for the controller.
    Yet when I open Triden and goto Devices, it is listed as such:
    Speed: Full
    State: Running
    Class: Vendor
    Bindings: xbox360.class
    When I double click it, I don't get the menu I would get with my PS2 controller where I could bind the buttons to keys on the keyboard.
    Could I be doing something wrong?
  • »20.02.14 - 12:19
    Jupp3
    Posts: 1193 from 2003/2/24
    I don't have a XBOX360 controller, so no idea how exactly it should work...
    But as far as I know, USB HID devices use the "old" lowlevel.library, and can also be bound to keyboard, mouse coordinates etc.
    X360 controllers, on the other hand, use the new sensors.library approach, which is the successor of lowlevel.library. Currently there's (afaik) no lowlevel.library wrapper, so for controller to work, programs must support sensors.library directly. Currently only X360 controllers are supported by sensors.library. So if a program wants to use both standard usb hid controllers & X360 pads, it must support both lowlevel.library and sensors.library.
    Of course at some point there likely will be both lowlevel.library wrapper for sensors.library and sensors.library support for other input devices.
  • »20.02.14 - 12:34
    XDelusion
    Are there any games that support this new library that you are aware of?
  • »20.02.14 - 14:44
    Posts: 12557 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8639&start=64
  • »20.02.14 - 15:36
    SoundSquare
    Posts: 1214 from 2004/12/1
    anyone tried the Xbox One pad on Morphos ? I'd prefer it to the PS4 one.
  • »20.02.14 - 18:58
    Posts: 3336 from 2003/3/5
    Papiosaur wrote:
    The Dual Shock for PS4 work very fine on MorphOS...
    "Fine" as in the limited scope of what lowlevel.library can do...
  • »21.02.14 - 06:33
    weiseb
    Posts: 215 from 2003/3/29
    @jupp (and jacadcaps)
    > input devices.
    Is this just a sensible assumption or somewhere mentioned as a goal.
    I am all for it but I see a tendency to drop legacy support like warp3D,
    so I would not be surprised if there will be no lowlevel.library wrapper.
    I do understand the wish to push the developers to support the new library and
    its enhanced feature set but I would love to use some Games and Emulators that are not in development any more with my XBox 360 controller.
  • »21.02.14 - 07:23
    weiseb wrote:
    (...)I would love to use some Games and Emulators that are not in development any more with my XBox 360 controller.
    Of course. The goal is to replace current lowlevel.library with a wrapper to sensors.library.
  • »21.02.14 - 07:59
    weiseb
    @jacadcaps
    Thank you for the answer. I am glad the wrapper is planned.
  • »22.02.14 - 10:38
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    Just tested the PS4 pad with morphos, yes it does work! Although it did not work for me in FPSE after configuring the pad plugin, but all other games working fine!
  • »01.11.15 - 19:01
    tolkien
    Posts: 585 from 2013/5/29
    I have problems with FPSE and PS4 gamepad too. Works good with other games/emulators.
  • »01.11.15 - 19:13
    Yasu
    Posts: 1724 from 2012/3/22
    Ask BSzili. He can probably help :-)
    My MorphOS blog
  • »01.11.15 - 19:36
