Efika Serial Port as MIDI port?
    XDelusion
    Posts: 602 from 2010/10/27
    Could something be wired up to the serial port on the back of the Efika to act as a standard MIDI controller that something like HD-Rec could use?
    EDIT: MIDI Schematics
    http://www.cinetix.de/interface/tiptrix/midi2rs.htm
    [ Edited by XDelusion 22.02.2014 - 19:17 ]
  • »22.02.14 - 22:30
    Posts: 3336 from 2003/3/5
    You would need a serial.device driver for Efilka first...
  • »23.02.14 - 06:40
    Posts: 1390 from 2010/1/6
    Yeah! Many of us are waiting since years for such a device.......(would make EFIKA a bit more useable....)
  • »23.02.14 - 06:51
    XDelusion
    In the words of Ziggy,"Sigh..."
  • »23.02.14 - 07:39
    Posts: 847 from 2007/10/23
    What about a standard USB MIDI interface?
  • »23.02.14 - 15:35
    XDelusion
    I believe that all comes down to the camd.library. I had discussed this before a long time ago when I was using an eMac, and I can't recall the exact answer I got, but I believe it had to do with camd.library needing a MorphOS specific update or something or other.
    I'm sure someone will come along and shed light on that...
    ...man, my Efika feels so self contained, no way to reach out and express itself. :)
  • »23.02.14 - 20:18
