32Mb VRAm vs 64Mb VRAM?
    Posts: 45 from 2013/8/19
    How bad is 32Mb?
    I cannot find a Mac Mini with 64Mb VRAM and I'm not sure I could handle the noise and power usage of a Power Mac despite them being so much cheaper (it would be on 24/7 in the lounge).
    I'm looking to buy today.
    How bad is 32Mb VRAM?
    does it slow things down that badly/stop software working?
    thanks
    (also, if any admins of the site read this, when I get email replies to my posts, the only link in them is to stop getting notifications, there isn't one just to read the thread)
  • »06.09.13 - 08:29
    Derringer
    Posts: 103 from 2008/8/4
    if you stay on 1280*1024 desktop and turn off enhanced display it is ok. You can run RTCW or quake3 on 1024*768 at full spec.
    If you wan more forget 32Mb and even 64.
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »06.09.13 - 09:16
    Cheers, I don't play many games, will be more desktop and various utilities, maybe the occasional game of SWOS
  • »06.09.13 - 09:30
    Posts: 2564 from 2003/2/24
    Your UK ?
    Quick look onto ebay:
    No1
    No2
    Just searched "mac mini g4 1.5" +include description
  • »06.09.13 - 09:47
    Yasu
    Posts: 1724 from 2012/3/22
    Maybe if you want to surf with OWB and play RTCW at the same time 32 will not be enough. But for everyday use 32 is enough, even though it's not as "hot" as 64, since you have to be careful not to use it all up. I have 128 on my G5 and that's more than enough for everything (except playing Duke Nukem 3D with the HI-RES graphic expansion pack. Then even 128 isn't enough for smooth playing. I use LOW-RES graphic expansion pack instead).
    My MorphOS blog
  • »06.09.13 - 11:06
    I only have 32mb of VRAM in my iBook and it works fine for the applications I use.
  • »07.09.13 - 17:25
    @Jim
    Yeah, at 1024x768 ......
    Doubt anyone would use such a small desktop monitor these day.
  • »07.09.13 - 17:28
    Kronos wrote:
    @Jim
    I do on a regular basis.
    I can't imagine trying to view higher res on a 14" LCD.
    And for most applications its adequate.
  • »07.09.13 - 17:34
    Yasu
    @Kronos
    I used my Mac Mini with 32 MEG VRAM with 1920x1080. It worked fine, even with OWB running.
    My MorphOS blog
  • »07.09.13 - 19:46
    XDelusion
    Posts: 602 from 2010/10/27
    I had an eMac and always found my self pressing the memory limit. Get something with 64 at the VERY least.
  • »08.09.13 - 01:22
