Install problems on power mac g4
  • Dav
    Posts: 10 from 2013/6/8
    hi guys, I have been trying to install Morphos 3.2 on my G4 for a while now but have so far not got it to work. Once I tell it to boot from the cd it just sits at a white screen and will go no futher.
    I have tried other cd/dvd drives but same thing happens, tried to install from usb but being my first mac have not been able to get that to work either.
    So, can anyone help me out getting this installed? Or maybe I can try install 3.1 instead? Haven't been able to find an iso for 3.1.
    Thanks for having a look.
  • »08.06.13 - 02:00
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hi Dav,
    Is your PowerMac is suppored by MorphOS 3.2 ? See this hardware compatible list :
    http://translate.google.fr/translate?u=http://obligement.free.fr/articles/modeles_identifiants_ordinateurs_apple.php&sl=fr&tl=en&hl=fr&ie=UTF-8
  • »08.06.13 - 04:16
  • Dav
    It is a Power Macintosh G4 1.25 DP (MDD) PowerMac3,6, says that is is supported but no good so far.
  • »08.06.13 - 04:46
  • ASiegel
    Posts: 1397 from 2003/2/15
    Find a download link for 3.2 and replace the "2" in the link with a "1".
  • »08.06.13 - 05:01
  • Dav
    Thanks ASiegel, legend!
    EDIT - Just tried 3.1 and got the same result, freezes saying something about cpu lock.
    [ Edited by Dav 08.06.2013 - 18:26 ]
  • »08.06.13 - 05:10
  • Dav
    Graphics card is a radeon 9000 pro which is on the list. Everything says it should work, strange huh?
  • »08.06.13 - 12:14
  • ASiegel
    The exact error message might be useful.
  • »08.06.13 - 12:35
    Doffo
    Posts: 508 from 2010/10/14
    Had this annoying problem before. Switch your CD drive. Though it starts to boot up, its aged and it struggles. Just get any newer IDE pc drive, then remove its front faceplate, then replace the current one in your mac.
    YUUUP!
  • »08.06.13 - 18:03
  • Dav
    Tried 4 different cd/dvd drives now all had the same thing happen.
    The message that it stops on is:
    Quark/OpenFirmware
    console active
    System: <PowerMac3,6> Rev <>
    CPU0: <PPC7455> Version 0x8001 Revision 0x303
    CPU0: CPUClock 1249999995 BUSClock 166636859
    CPU1: <PPC7455> Version 0x8001 Revision 0x303
    CPU1: CPUClock 1249999995 BUSClock 166636859
  • »09.06.13 - 02:11
    Norbi
    Posts: 99 from 2004/6/19
    try my method
    -need pendrive FAT32 max 512MB or create partition 512MB fat
    -copy ISO and boot.img to pendrive FAT
    -Start with the built usb (OF)
    boot usb0/@1,boot.img umsd0:morphos32.iso
    or
    boot usb1/@1,boot.img umsd0:morphos32.iso
    Can you write me how to effect?
    ps
    it works on my PM and MM
  • »09.06.13 - 14:55
    Doffo
    Also, not sure if swapping jumper positions will help. Set it to either slave/master. Worth a shot. :)
    YUUUP!
  • »09.06.13 - 18:24
  • Dav
    Thanks for the reply guys, really appreciate your help. I tried to boot from usb again using the command from Norbi but as soon as i press enter i get a LOAD-SIZE is to small message. Tried a few other ways I found to boot from usb and the furthest i got was a screen with:
    Loading ELF
    Quark/OpenFirmware
    console active
    DO-QUIESCE finished
    Tried all the dvd drives I had in master, slave and cable select as well, no good :-x
  • »10.06.13 - 01:39
    Oscar
    Posts: 17 from 2011/12/11
    I'm having issues of freezing as well. Under MOS 3.1, which I just reinstalled, I have no issues at all. Same hardware with MOS 3.2 and I can't get passed the install. Copying a file or trying to start app locks it all up. WHen I get my graphics card in for my G5, I'm going to try installing it there and see if I get the same problems.
    PowerMac G4-Dual 1.42GHz-Radeon 9600 Pro-MOS 3.1-120GB SSD
    PowerMac G5-Dual 2.0Ghz-Radeon 9800 Pro-MOS 3.2-120GB SSD
  • »10.06.13 - 01:50
    Norbi
    I have not checked my post when send
    Was error.
    Must be:
    boot usb0/@1:,\boot.img umsd0:morphos32.iso
    or
    boot usb1/@1:,\boot.img umsd0:morphos32.iso
    check it again
    [ Edited by Norbi 10.06.2013 - 18:52 ]
  • »10.06.13 - 14:51
  • Dav
    That didn't work for me either, i get the same messages as before.
  • »12.06.13 - 06:36
    shaf
    Posts: 15 from 2013/6/11
    what is umsd0: on a Ibook G4 the command won't work is says device not detected.
    Also how can you tell ir you have the proper 3.2.iso I've tried to Download it again and no change in any files or filesizes from root.
  • »13.06.13 - 02:46
    Doffo
    Only last things I can think about trying is resetting the settings on the board via that small button on the mainboard. Not sure if swapping out the CPU module will do much, but worth a shot. :P Picked up a 1.25ghz single cpu card for $13 shipped on fleabay. This way my MDD runs much cooler. :)
    Hope you get it sorted out! It shouldn't be this much hassle.
    YUUUP!
  • »13.06.13 - 03:32
    Posts: 12558 from 2003/5/22
    Compare the MD5 sums.
  • »13.06.13 - 06:11
    Norbi
    umsd0: - this is name device FAT in Morphos system
  • »13.06.13 - 15:46
    Intuition
    Posts: 1116 from 2013/5/24
    On a Powerbook you do this. I assume it's the same for an iBook.
    boot ud:,boot.img bootimage=umsd0:morphos-3.2.iso
    In Ambient, right click the iso image, click Information, click MD5.
    [ Edited by Intuition 13.06.2013 - 20:16 ]
  • »13.06.13 - 17:12
