Memory List for Peg2
  • Targhan
    Posts: 2833 from 2003/2/7
    Hey guys, just started on an incompatability list for the Pegasos-2.
    You can find the quick page following this LINK.
    Now, I'm going to need your help, as you can see there is only one entry on the list. Bear in mind this is a user-tested list and not an "official" set of tests from bPlan, Genesi, resellers etc. Should those official reports start appearing they will be marked as such. So, start throwing up some replies, let's find out what doesn't work and save our neighbor from some headaches!!
    (Big thanks to oGALAXYo for reminding me to get this project kick-started.)
    :idea:Targhan
  • »24.01.04 - 18:01
    nels664868
    Posts: 117 from 2003/12/28
    Kingston ValueRAM 512M PC2700 #KVR333X64C25/512 works.
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »24.01.04 - 18:26
    magnetic
    Posts: 2129 from 2003/3/1
    Good initiative Targhan
    PNY OPTIMA MEMORY 256mb PC2700 DDR333mhz Works
    It is important for all people with Pegasos boxes to report their findings...
    TIA
    magnetic
  • »24.01.04 - 19:39
    Posts: 157 from 2003/3/3
    Targhan: I have been having two sets of Rams for Pegasos 2 and both seem to bee 100% functional.
    Kingston PC2100 2* 128MB
    Twinmos PC3200 2* 256MB
    I don't have any more details of them, sorry...
    http://somequicknotes.blogspot.com/index.html
  • »24.01.04 - 20:38
    MaSC
    Posts: 63 from 2003/12/1
    Don't forget this list.
  • »24.01.04 - 20:54
    Chain-Q
    Posts: 350 from 2003/10/12
    Seeing all the problems people have i must tell, i just went into a local PC-store, bought a 256MB DDR 2700 RAM, plugged in, and it works well. I do not even know what kind of memory chips are on it. What did i do wrong? :-D
    (Pegasos 2 w/ G4/1Ghz, Radeon7500)
    [.Hosting AmigaSpirit.hu.]
  • »24.01.04 - 22:45
    Senex
    Posts: 500 from 2003/2/17
    Xtreme DDR 266, 512 MB -> memtest failed, sound distortion, format&verify didn't pass
    TwinMOS DDR 400, 512 MB -> everything alright
  • »25.01.04 - 05:22
    Toto
    Posts: 268 from 2003/4/20
    2x PC3200 256MB 32*8 (Infineon chips) DDR 400 modules. Works, no problems with memtest.
  • »25.01.04 - 13:19
    Posts: 43 from 2003/9/1
    These don't work in my Pegasos 2, it's either my Pegasos 2 or the RAM. So by any means avoid them and get modules from other manufacturers:
    Micron: mt8vddt1664ag-265a1
    2x128mb, single sided
    Infineon: hyb25d128800at9207by
    1x256mb, double sided, cm266/256/3rd, 16x8 pc266
    Lei: 88lshdl0-1pd6
    1x512mb, double sided, 64x64, pc2700, cl2.5
  • »25.01.04 - 13:39
    tarbos
    Posts: 221 from 2003/4/19
    MCI/MDT DDR 512MB PC400 2Bank 256M Chip (32x8) M512-400-16
    Works fine in 2 module (=1GB) configuration.
    Oh yes, and my antistatic foam is PINK!
    Too bad the Peg1 memory list wasn't updated with my reported RAM.
  • »25.01.04 - 16:17
  • Targhan
    Thanks for all the replies, I'll try to get the list updated. :-)
    :idea:Targhan
  • »26.01.04 - 02:17
  • Targhan
    Okay, the current version of the memory list: Peg2 Memory Page.
    Note: This list is not in it's final home yet, so the link address may change in the near future.
    :idea:Targhan
  • »26.01.04 - 14:54
