Frogatto
    BSzili
    Posts: 559 from 2012/6/8
    To make up for the last two fiasco (more details later), I decided to prepare a little Christmas present. It still has the debug output enabled, but I've spent quite some time cleaning up the main loop, so it's probably as fast as it gets. The MorphOS executable:
    http://bszili.morphos.me/ports/frogatto-mos.lha
    The cheapskates can download the game data for free from github:
    https://github.com/frogatto/frogatto/archive/1.3.1.zip
    This includes a lots of non-Frogatto related stuff, so it's much larger than the stock game (about 500 MB).
    If you want to support the developers, you can buy the game here for ten bucks:
    http://www.frogatto.com/download
    If you want to support me, I have a begging segment on my homepage... :-)
  • »22.12.13 - 13:00
    defender
    Posts: 248 from 2011/4/24
    Thanks a lot, for your work ... send some bugs to keep you going man !
    Just can t wait for the download to finish :-)
    greets defender
  • »22.12.13 - 16:31
    defender
    :-) it works - no problems here ... thank you BSzili (I am away - playing)
    Happy Christmas to all of you :-) :-) :-)
  • »22.12.13 - 18:52
    tolkien
    Posts: 502 from 2013/5/29
    Thanks for this game! It looks great.
  • »22.12.13 - 20:07
    Posts: 564 from 2004/4/15
    My daughter and I loving it!
    THX a lot!
  • »22.12.13 - 20:12
    BSzili
    I recompiled the executable with more optimization flags enabled, it should have sligtly better performance now. I added a FULLSCREEN tooltype too, so you don't have to press CTRL+F each time you run the game.
  • »23.12.13 - 13:30
    BSzili
    Frogatto has no built-in language selection, but it autodetects the system locale on Windows an unices. I'll investigate the issue.
  • »23.12.13 - 15:14
    Papiosaur
    Posts: 2053 from 2003/4/10
    Thanks BSzili !
    I tried to edit the config file in modules / Frogatto / .tx but without success ...
  • »23.12.13 - 16:45
    BSzili
    I don't know which config file did you edit, but as I said you can't set the locale from the game. It's autodetected at startup and not stored anywhere, so you have to wait for my fix.
    [ Edited by BSzili 23.12.2013 - 20:55 ]
  • »23.12.13 - 17:45
    BSzili
    It was a combination of two problems (no LANG env var on MorphOS, endianness issues). It's probably working now, but oddly I can't run the game anymore. I get crashes in tinygl.library when the OpenGL extension string is queried (access to deadbeef). I'm not sure what did I change that broke the game this bad, but I can't release it this way.
    edit: As a stopgap solution I reverted to using the "Language" env var now, which means that the first of your preferred system languages will be used by Frogatto.
    [ Edited by BSzili 24.12.2013 - 11:55 ]
  • »24.12.13 - 11:09
    Jambalah
    Posts: 820 from 2008/3/30
    Nice work BSzili!
    Thank you very much and have a nice XMas!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.12.13 - 14:31
    peg4a
    Posts: 26 from 2003/4/15
    Thanks a lot man you rocks !!!
    I can play Frogatto in French !!
    Peg4a happy :)
    Powermac G5
    2,3 giga mono processor. HDD : 750 Go sata ATI 9800 XT 256 mo.
    Morphos 3.4 ;)
  • »24.12.13 - 17:53
    scrAb_
    Posts: 62 from 2010/7/23
    Thank you Bszili ... really, we're enjoying it :-)
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »24.12.13 - 17:59
    defender
    Damn I love this game, thanks Bszili for porting it! :-)
  • »29.12.13 - 21:33
    Cool_amigaN
    Posts: 750 from 2011/11/30
    Ah, Frogratto, I remember this game several years ago when the project started and everyone likened it with Superfrog. Back then when I tried it it was an alpha/unfinished version with only a small portion of the levels finished.
    The game was brought up to my radars after the AmigaOS port but my Sam was/is so underpowered that it couldn't run it decently.
    Afterwards I decided to install it on my Win/PC but I faced a huge problem with language detection with Frogatto (which reminds me BSzili's saga mentioned above): The game was insisting using mixed up Greek fonts even though my system is setup as English/American. The result was to produce/use some hieroglyphic utterly incomprehensibly characters in the game's dialogs ultimately resulting into not being able to understand what I was supposed to do next :(
    I was hoping for a MorphOS version! Hope everything runs fine this time :) Will try it asap today evening, after work. Many thanks for all of your efforts, keeping us busy with new games! :)
    [ Edited by Cool_amigaN 30.12.2013 - 09:50 ]
  • »30.12.13 - 08:49
    Yasu
    Posts: 1724 from 2012/3/22
    I hope you can solve the language problem (Swedish translation is unfinished and that is annoying). Another great port! :-D
    My MorphOS blog
  • »10.01.14 - 13:55
    BSzili
    I won't finish the Swedish translation, if that's what you are referring to :-P
  • »10.01.14 - 14:28
    Yasu
    @BSzili
    Ha ha! No no, I'm not that demanding :-)
    I meant being able to choose language would be nice,
    The screen flickers on my G5 with radeon 9600XT 128 MB VRAM when I move from side to side. Is this a known problem?
    My MorphOS blog
  • »10.01.14 - 15:43
    BSzili
    I'll add some tooltype which can override the automatic language detection. They really should add a language selection screen already...
  • »10.01.14 - 16:54
    Yasu
    @BSzili
    Cool! How about the other problem?
    My MorphOS blog
  • »10.01.14 - 17:24
    BSzili
    No clue, what was the other problem again?
  • »10.01.14 - 17:47
